REplacing Clutch with OEM clutch parts...
I Know I need:
1) Clutch Disk
2) Pressure Plate
3) Release Bearing
4) Alignment Tool
5) Flywheel resurfacing
But what is a:
6) Release Fork
Thanks in advance.
1) Clutch Disk
2) Pressure Plate
3) Release Bearing
4) Alignment Tool
But what is a:
6) Release Fork
Thanks in advance.
it's the fork that holds the TOB and is pushed on by the slave cylinder. it usually doesn't need to be replaced unless it's visibly worn down at it's contact points. i couldn't see that happening until very high miles though.
