Stripped screw on intake manifold suggestions?
Old Feb 25, 2007 | 08:13 AM
Sharkbite2000's Avatar
I would like to see what you guys think i should do to fix or replace?
On the throttle bodie side one of the screws stipped the intake manifold so its not holding. They said i should just use a healycoil to fix it but i think thats a temporary fix to the problem. I just wanted to replace the intake and get a new one or do you guys think it not gonna be a problem.
Old Feb 25, 2007 | 11:21 AM
Jasil's Avatar
Nothing wrong with heli-coils used all the time in soft metals to increase TQ capacity.
Old Feb 25, 2007 | 11:25 AM
dan l's Avatar
Helicoils are NOT a temp fix. THey are actually a BETTER fix. I put them in all my exhaust threads because the steel helicoils take more abuse than the aluminum threads. This is common practice on aluminum parts that are serviced a lot.
Old Feb 25, 2007 | 11:32 AM
Exciting News's Avatar
If you do it the correct way a heli coil will last longer than you own your car. You could also try a threaded insert which is bit more time consuming and stronger than a heli coil. Probably overkill for the TB.
Old Feb 25, 2007 | 12:25 PM
cfdfireman1's Avatar
+1 for heli-coil
Old Feb 25, 2007 | 01:28 PM
EVO8904's Avatar
Originally Posted by cfdfireman1
+1 for heli-coil
here can I find heli-coils?
Old Feb 25, 2007 | 01:36 PM
Paul Nelson's Avatar
Bah just used JB weld
Old Feb 25, 2007 | 02:11 PM
JB weld ? Sound like the helicoil is not gonna be a problem sounds good just don't wan't any problems later on in the future especially with a Custom part that i can't get no where.
Old Feb 25, 2007 | 02:15 PM
BiFfMaN's Avatar
http://www.timesert.com/
i have had better luck with time serts when fixing totally f@#ked up threads...even works good in aluminum and can hold more torque. if not heli-coil will do you just fine.
Old Feb 25, 2007 | 02:22 PM
Now that looks like it will work alot better.
Old Feb 25, 2007 | 10:31 PM
That's actually what I was alluding to in my previous post. I have a time sert as one of my spark plug threads right now. Rock solid.
Old Feb 25, 2007 | 10:35 PM
LancerEVA06's Avatar
I say heli-coil too, but always the option of drilling a little bigger and re tapping.
Old Feb 26, 2007 | 05:57 PM
well dan at pruven said heli-coil will give no problems , he said if it gives me a problem he will fly down to flordia and fix asap. Hard to belive but ok as long as it doesn't mess up.
Old Feb 26, 2007 | 06:00 PM
RTV son
Old Feb 26, 2007 | 06:06 PM
Whats RTV ?
