cat + slow = very
Old Feb 28, 2007 | 10:03 AM
Noize's Avatar
EvoM Administrator
cat + slow = very
I'd like to see some dyno graphs: Test pipe vs. high flow cat. Has anyone done this?
I know that not all aftermarket high flow cats are created equally. I've seen a few Evos that do great with them on the dyno. Unfortunately, mine seems to be quite a bit restrictive.
If you've made really good power with an aftermarket cat, would you please post up the brand you are using?
Thanks in advance!
Old Feb 28, 2007 | 10:05 AM
tweakdsm's Avatar
huh?
Old Feb 28, 2007 | 10:06 AM
boostinjuice's Avatar
Get a test pipe.
Get metal and cover it it to make it look like a cat!
Someone on here has done it
Old Feb 28, 2007 | 10:08 AM
MR. Birdie's Avatar
CAT = boooo =)
Old Feb 28, 2007 | 10:12 AM
Noize's Avatar
EvoM Administrator
Originally Posted by tweakdsm
huh?
Sorry, I was typing in the middle of something at work. I edited the post, took out the extra fluff, and made it read a little bit clearer.
Old Feb 28, 2007 | 10:13 AM
Mitsu3's Avatar
i got a cat on my IX and made 334hp 338tq at TT.
Mods are licp,k&N drop in, ams tbe w/hfc, hallman mbc 22psi, walbro255, and tune
I got the cat for less noise and so i can pass emissions in NY.
How much do you think i will make without the cat?
Old Feb 28, 2007 | 10:17 AM
Noize's Avatar
EvoM Administrator
I think it would pick up about 15whp on my car, but not sure about yours. I was having a lot of issues with boost retention on the dyno, and I suspect the brand of high flow cat I'm using.
UT_Evo's Avatar
Sigh... no one, for this long... Anyway... Here's my story:
Local dyno day, me with dynoflash turboback catless and a k&n drop in... Another guy, same year of evo, same dynoflash that was done on the same day mine was, k&n drop in, and a turboback exhaust with a high-flow cat.... The result:
About 10-15 whp difference between all the dyno runs.
Both were '03 Evo VIIIs, one was blue, the other silver (so, I guess the silver could make more power, cuz silver > bby)
Old Feb 28, 2007 | 10:20 AM
KartaRailed's Avatar
It was definatly the silver color. At any rate, HFC's rob power, its a sacrifice you may have to make due to location, but florida dosent have emissions testing, so im all over that off road pipe.
Old Feb 28, 2007 | 10:23 AM
saiyanzzrage's Avatar
this + thread = useless
Old Feb 28, 2007 | 10:30 AM
hotrod2448's Avatar
I don't have dyno sheets but I can tell you that I picked up what felt to be considerable amount of power trading my Helix HFC for a test pipe.
I picked up 2PSI of boost and it doesn't taper nearly as bad at high RPM's as it did with the HFC.
Old Feb 28, 2007 | 10:40 AM
Noize's Avatar
EvoM Administrator
you + gay = absolutely.
If you don't like a thread, GTFO.
Old Feb 28, 2007 | 10:49 AM
Noize's Avatar
EvoM Administrator
Thanks, K!
Old Feb 28, 2007 | 10:54 AM
boostedwrx's Avatar
I did 333whp/335ftlbs with a HFC. I put in a test pipe and the butt dyno definately noticed it up top. The motor felt less restricted up top. Dont have a dyno to prove the after but i could def tell the car was faster.
Old Feb 28, 2007 | 11:01 AM
evo637's Avatar
I would run a test pipe, but here in California it's a big gamble..Dont want to risk a huge fine..You could also purchase a stealth test pipe (test pipe stock cover)..
