help with adding powa
Old Feb 28, 2007 | 09:58 PM
IAmADirtDude's Avatar
I have an intake and ground kit right now and would like to add more power. I dont want to add more noise if possible because it is my DD so i was thinking about installing pully's and maybe a light weight flywheel... anyone got any opinions without having to tear into the engine?
Old Feb 28, 2007 | 10:00 PM
newimportowner's Avatar
Put your Box back in w/o a tune and use a Drop in Air Filter, Boost Controller, Yank the Cat, Dont do a pulley or fly wheel. Jeez your worried about tearing into your engine but willing to seperate the Transmission from the engine?
Youll feel a difference.
Old Feb 28, 2007 | 10:04 PM
wroblewskievo's Avatar
get rid off the intake and do the normal mod path. tbe, drop in filter, fuel pump, mbc, and tune and you will be good for around 300awhp. the car will feel great and be reliable as a daily driver. the pulleys and flywheel should be done after the mods i mentioned. plus the intake makes the car louder. good luck and enjoy.
