Recommended Max RPM for BR Springs
Old Mar 3, 2007 | 08:21 AM
joedr's Avatar
EvoM Moderator
Question Recommended Max RPM for BR Springs
All,
Here is my dilema... I own a 06 MR and I am getting my 1/4 messed up because I either have to shift to 5th gear or increase the rev lim to croos the final line.
I ordered some GSC S1's for the car and was looking to get the BR Springs to be able to raise the rev lim.... right now at ~7800. I think that I need only 500 RPMs to cross the final line but certainly do not feel comfortable to raise the rev lim to there w/o upgraded valvetrain.
Any suggestions on what will be a safe number to set the rev lim? Any other suggested mods to been able to accomplish the final goal w/o having to swap gears/Final Drive in the tranny?
Old Mar 3, 2007 | 08:27 AM
mchuang's Avatar
I am not sure what BR springs are, but if it is valve train such as springs and retainers then you should be fine. I personally would use supertech, but I am sure if Buschur makes a spring and retainer it is probably tested before to make sure it can keep your valves from floating or dropping at high rpm.
Old Mar 3, 2007 | 08:34 AM
joedr's Avatar
EvoM Moderator
Oooops! By that I refer to the Buschur Racing Custom Dual Springs and retainers.
The actual product can be found in here: https://secure.buschurracing.com/cat...products_id=38
Old Mar 3, 2007 | 08:41 AM
BURNALL_4's Avatar
just raise it to 8500 even if you dont go that high its there incase.....you wont hurt anything anyway......especially if you do springs and retainers.
Old Mar 3, 2007 | 08:48 AM
mchuang's Avatar
The stock springs and retainers are pretty stout, 8500 may be pushing it, but 7800 to 8000 should be fine. I would personally wait to get springs and retainers for piece of mind though lol
Old Mar 3, 2007 | 08:49 AM
joedr's Avatar
EvoM Moderator
Actually, I shift gears around 7000 RPMs depending on gear and only would like to cross the final line at 1/4 track w/o having to shift to 5th gear.
I am getting better in shifting to 5th but still I am better off not using it! Thanks for the advise!
Old Mar 3, 2007 | 11:28 AM
JohnBradley's Avatar
Only trapping 110.6 I wouldnt bother shifting into 5th. It doesnt seem to become a problem till 113.5+ or so in my experience. Crossing the big end 8K+ is where it kind of can be iffy. In my MR I am seeing over 8000 actually crossing the line which is always a higher speed than the trap plus the fact that no one I know lets off exactly at the 1320 mark.
Once the weather gets better and I feel going to the track will be worthwhile here in the NW, I will post logs with proof of RPM in 4th at a given trap speed. Joe, I am curious how you get consistent shifts into 5th with your 6 speed? Mine seems to like to lock me out to the point where I am never sure if its going to be worth it to try. I hate running 12.11 @ 108.1 cause I couldnt get that last gear and coast the traps.
Old Mar 3, 2007 | 11:47 AM
steelcityevo8's Avatar
the buschur racing dual springs & retainer are good to 9k + . that info provided to me from a pm from David himself. i have orderd a set myself but have not installed them yet waitin to get the Buschur secret camshaft set. those springs are actually supertech spring/ retainers, i guess Buschur spec cause they came packaged in supertech packaging
Old Mar 3, 2007 | 01:01 PM
Paul Nelson's Avatar
I know on my stock setup my 5 speed trap 8200rpms at 125 each time and 121 was 8000rpm.
Right now we were testing 9000rpm and the aem said 142mph
Old Mar 3, 2007 | 08:50 PM
Thanks for the input Paul. The problem is VIII 5 speeds are different than even IX 5 speeds let alone the MR box. MR's are lower geared than the 5 speed and have a low geared 4th on top of it. I think Lucas is gonna get a visit so I can get a clutch.
Austispu
Jun 8, 2016 08:11 AM
danfalcas
Sep 30, 2015 08:25 PM
Marcus Lim
Sep 2, 2014 11:27 PM
RallliartEVO6
May 31, 2007 04:10 PM
Dem_z
Lancer Aftermarket Forced Induction Tech
26
Jan 17, 2007 02:01 PM
