Valve/retainers and bov q's
Old Mar 4, 2007 | 02:31 AM
Jspec EVO VIII's Avatar
So i was browsing around for some springs and retainers. Would single springs be ok for a 20g9lt upgrade? I'm looking into purchasing the set through GSC along w/some other goodies. For the Forge RS, is the knob version recommended as well? Thanks
Old Mar 4, 2007 | 12:01 PM
EVOlutionary's Avatar
Turbo size has nothing to do with springs. You need stiffer springs if you have large cams and/or plan to rev your motor past ~8000 rpms . . .
Sorry, no info on the Forge . . .
EVOlutionary
Old Mar 4, 2007 | 12:11 PM
Paul Nelson's Avatar
Im running the BC plus 1 valves,spring,retainers. Were revving to 9500 with no valve float
Old Mar 4, 2007 | 12:19 PM
Mike@Forge's Avatar
Different/upgraded valve springs would only be required and would only be of benefit if you're going to be upgrading to cams with higher lift than stock cams. It has nothing to do with turbo size.
Concerning our RS valve, it is only available with an adjustment knob. You can't get our RS valve without it. If you want to forgo the adjustment knob, you'll be looking at our Evo15 valve instead.
Old Mar 4, 2007 | 05:43 PM
Yeah i'm running 280s.
Old Mar 4, 2007 | 05:49 PM
dubbleugly01's Avatar
which 280's? If it's GSC 280's, you don't need upgraded springs unless you plan on running past 8000 rpms consistently.
Old Mar 4, 2007 | 06:14 PM
hks
Old Mar 4, 2007 | 06:40 PM
Warrtalon's Avatar
Same answers you got on Evotuners yah except for the "single spring" part. I still don't know what that means.
