Stalling problems...
Old Mar 8, 2007 | 08:43 AM
Azntoyhere's Avatar
Most possible, Check your By pass valve to see if its leaking or not. Might have to change a new one if your running 22-23 lbs of boost.
Old Mar 8, 2007 | 08:49 AM
kmcknight's Avatar
1. How do I check if my BOV is leaking?
2. Would that really be why it feels like it's about to stall?
Old Mar 8, 2007 | 08:52 AM
Azntoyhere's Avatar
How many lbs of boost are you running now with the MBC?
Old Mar 8, 2007 | 08:54 AM
kmcknight's Avatar
like I said in my original post 20-21 lbs.
edit. There is no question in my mind whether or not my stock BOV is or will eventually leak with these conditions, however this does not explain why my car feels like it is going to stall out when I start to drive away...
Old Mar 8, 2007 | 09:40 AM
turbo8's Avatar
did you cap the vacum line that goes under the intak to the boost sielonoid.
Old Mar 8, 2007 | 09:50 AM
kmcknight's Avatar
like i said earlier I connected it to itself, therby "capping" it
