MBC Hose Size
Old Mar 16, 2007 | 02:22 PM
mdsevo06's Avatar
MBC Hose Size
I purchased a UNOS MBC and need Hose to run from the Turbo and the Wastgate. What size hose do I need and what caps should I use. I did search, but with no luck. I know Home Depo carries different size hoses, would this be good to use???
Thanks in advance
Old Mar 16, 2007 | 02:55 PM
Warrtalon's Avatar
Whatever fits snugly.
Old Mar 16, 2007 | 03:06 PM
AF-Evo8's Avatar
take you mbc to autozone or advanceauto and find the right hose that fit snugly
Old Mar 16, 2007 | 03:27 PM
merkzu's Avatar
Fit the hose for the turbo and wastegate nipples, the forge mbc nipples are larger and you might get too big of hose. Hose is cheap, get a couple of sizes if you're really not sure.
Old Mar 27, 2007 | 06:49 AM
FiftyFive's Avatar
4mm bore works good, 3mm bore for an extremely snug fit.
Old Mar 27, 2007 | 03:06 PM
19psi's Avatar
ditto.
Old Mar 27, 2007 | 03:15 PM
BoostEEd's Avatar
HAHAHA. Try walking into an auto parts store and ordering vacuum hose in metric around here and they will look at you like your talking another language.
But yeah get VACUUM line from an AUTOPARTS store and just take the MBC with you.
