MAP conversion question
Old Mar 19, 2007 | 03:52 AM
arpad's Avatar
When converting to MAP, does the manifold differential pressure sensor (#33 on the attached picture) on the intake manifold get disconnected?
Thanks!
Old Mar 19, 2007 | 05:12 AM
Planet Evo's Avatar
Are you running an AEM EMS?
Old Mar 19, 2007 | 06:16 AM
arpad's Avatar
yep
Old Mar 19, 2007 | 03:15 PM
Planet Evo's Avatar
Then yes it does
Do you need a pin color code to match up the wires?
Old Mar 19, 2007 | 10:47 PM
arpad's Avatar
No thanks, I'm just planning ahead for my intake manifold.
Thank you for the info!
Old Mar 20, 2007 | 04:52 AM
kjewer1's Avatar
MDP is only used by the ECU to verify EGR functionality. If this is not important to you (DSMlink, AEM, etc) you do not need the MDP sensor. It is concievable that you could do the MAP conversion and still keep a functional EGR, but I don't think anyone does.
Old Mar 20, 2007 | 10:35 AM
arpad's Avatar
sweet, thanks!
