Wastegate
Old Mar 19, 2007 | 02:30 PM
Street Solutions Racing's Avatar
Wastegate
So I have a Gt30r on the car now, of course the wastegate only holds to about 23 psi. Which wastegate is other Evo owners using??
Thanks!!
Old Mar 19, 2007 | 02:34 PM
o.e.boost's Avatar
wastegates do have spring pressure and should be holding quite well...not sure what you mean by holding 23psi...imho the tial 38mm should be able to handle pretty much everything you throw at it!!!
Old Mar 19, 2007 | 02:35 PM
Nez136's Avatar
boy if your WG spring pressure is 23 psi than your fine
Old Mar 19, 2007 | 02:37 PM
AF-Evo8's Avatar
the wastgate pressure is the minimum the you can run when using a MBC so with 23psi you should be fine.
