Boost Problem...??
Old Mar 22, 2007 | 03:36 PM
extreme evo's Avatar
Boost Problem...??
hi..ı have problem to hold boost at red line..boost is lowering by increasing rpm so much...exp:it peaks 1.85 bar and 1.35bar at the redline
ı have hks evc5 boost controller...
ı have invidia outlet pipe with evo9 turbo...
any idea?
Old Mar 22, 2007 | 03:58 PM
commentss??
Old Mar 22, 2007 | 04:26 PM
DynoFlash's Avatar
an HKS EVC 6 can control boost taper with a rpm depandant duty cycle
Boost taper on the stock turbo is normal and desired
1.85 bar is way too much boost unless you are running race gas and tuned for it
Old Mar 22, 2007 | 04:44 PM
MRgraphite's Avatar
I would definitely try and control that spike, unless it is tuned for as mentioned above.
Old Mar 22, 2007 | 07:01 PM
EVO MR 28's Avatar
1.85 is pretty high..
Old Mar 23, 2007 | 10:43 AM
1.85 bar is only peak..ı m running 1.4 bar continious...ı dont want to see high peaks...is this normal_?can invidia outlet pipe cause peaks?
what can ı do;?
