Am I cammed?
Old Mar 25, 2007 | 09:03 PM
Blk04evo's Avatar
Am I cammed?
The car was modified before I purchased it, but then they attempted to throw it back to stock.
My vac at idle jumps around between 17-18ish, and even under boost it looks like the boost gauge needle can't settle on 20, it jumps back and forth 19-20 very quickly. The idle is a little sloppy as well. And it idles around 850-900prm.
Am I dealing with a valve/engine issue?
Old Mar 25, 2007 | 09:14 PM
Brian's Avatar
Easiest way to confirm would be to pull the valvecover. It's only a 10 minute job and a great way to confirm it 100%.
Old Mar 25, 2007 | 09:16 PM
GT35REVO8's Avatar
+1 for that...valve cover takes about10-20mins...took mine off just last wkend...if you are cammed the company will have the name on the cam most likely...
Old Mar 25, 2007 | 09:17 PM
JohnBradley's Avatar
I would highly doubt its cammed. Thats very close to stock vaccum for a 4G63. My car went from 17/18 to 15 by just throwing in an exhaust cam.
Old Mar 26, 2007 | 03:47 AM
Blk04evo's Avatar
Ok, so should I be concerned that the vac doesn't hold steady at idle?
Old Mar 26, 2007 | 03:49 AM
AndyBandy's Avatar
the problem is, you can only tell IF its cammed, not the degree its cammed. i would try to contact the previous owner or something to try to find out.
Old Mar 26, 2007 | 03:52 AM
yas06IX's Avatar
sounds like your best bet is to contact the previous owner
