Will raising the boost cause
Old Mar 28, 2007 | 04:15 PM
EVO8904's Avatar
Oil Leaks? I found a oil leak today. It looked like it was coming from above the oil filter.
Old Mar 28, 2007 | 04:17 PM
TeStUdO's Avatar
Is your oil filter on tight? Maybe it is leaking from there.
Old Mar 28, 2007 | 04:48 PM
EVO8904's Avatar
It is on tight, I have never had a problem with that. I'm getting worried
Old Mar 28, 2007 | 05:17 PM
sonicnofadz's Avatar
Raising the boost usually does not correlate with oil leaks, unless you have a very bad blow-by problem. Do a compression test. This leak was probably just a coincidence.
