forge wastegate (uncontrollable boost)
Old Mar 28, 2007 | 11:59 PM
Dapper Dan's Avatar
installed a forge wategate and now my boost is out of controll its boosting way past 30 psi.......i checked and replaced all my lines....all the lines are hooked up correctly......i cant figure this out...any help/tips would be great...
Old May 10, 2007 | 10:44 AM
wotevo's Avatar
I know this mighth sound like a stuid answer but did you try removing the wastegate rod from the manifold and adjusting it down (turn towards the firewall).
Old May 10, 2007 | 11:17 AM
coolnick's Avatar
PM me if you want to sell it.
Old May 10, 2007 | 11:21 AM
kimletrim's Avatar
Registered User
Yeah, you need to adjust the knuckle bolt (part that attaches to wastegate flapper) and extend it.
Old May 10, 2007 | 01:55 PM
Mike@Forge's Avatar
Either the pressure reference to the unit is leaking somewhere prior to the unit, whatever type of boost control you're using is not sending a pressure signal to the actuator to open it, it's not adjusted properly, etc.
If you are not able to diagnose the issue yourself, please contact us directly and we will work to help you resolve the issue.
Old May 10, 2007 | 05:58 PM
uglyevo's Avatar
need more info, what are you running for a boost controller?
Old May 10, 2007 | 06:10 PM
EVO8904's Avatar
good luck man, my car does the same thing. I have a FP wastegate and my car will spike to 35.1psi when I have my boost controller turned on.
Old May 10, 2007 | 06:15 PM
uglyevo's Avatar
maybe you have it adjusted too tight. I have the fp and had the same thing, but then I readjusted it with less pressure and it fine now
Old May 10, 2007 | 07:08 PM
EVO8904's Avatar
I adjusted it and it still does it. My car only over boost when I have my Greddy EBC turned on. I even have my EBC set to 25psi.
Old May 10, 2007 | 10:58 PM
uglyevo's Avatar
what is the set gain at? try turning that down
Old May 11, 2007 | 09:45 AM
EVO8904's Avatar
I think it is set at 10, I'm not sure. I'll check after I get off work.
Old May 11, 2007 | 12:20 PM
uglyevo's Avatar
you may want to 0 everything out and start from scratch. what is the boost % set at?
Old May 11, 2007 | 01:31 PM
hawaiian_evo's Avatar
i had the same problem turned out the evc lines were hooked up wrong
Old May 11, 2007 | 02:48 PM
SteelEvo's Avatar
i have the forge wastegate no probs here
Old May 11, 2007 | 06:48 PM
EVO8904's Avatar
My gain was set at 5 and I have the boost set at only 22psi. I know I have all of the lines hook up right.
