2 quick cam gear questions
I am installing my cams and cam gears this weekend and have 2 quick questions. First, what is the recommended torque specs for the perimeter bolts on the adjustable cam gears? Second, which way do I rotate the cam to retard the timing? I plan on setting it up initially with the -4/-1 setting.
Thanks in advance!!!
which cam gears do you have?
