How is this tuning method accurate?
I've spoken with people from 2 reputable shops, but never got a clear answer.
When dynoing the car they check afr with a wideband sniffer up the muffler. How is this in any way accurate if the car is equipped with a cat? Cats store oxygen when momentarily lean, and use this to burn excess fuel when momentarily rich. I hardly believe that a cats effectiveness is linear across the entire rpm band. How can they safely tune a car with tampered a/f samples?
Thanks
Thanks
No they are not as accurate. Do you want to pay to have a bung installed to use just for tuning? They use the tailpipe sniffer because it is fast and easy. Most people dont have a bung in their DP so the tuner cant use that, so they use the tailpipe.
Less accurate AFR's, but the cats dont affect it enough, dont ask me how I know, I was just at a dyno day in miami today and I asked like 10 different people working there, and one of them gave me this long complex answer, so I just took his word for it.
why wud u want to take ur car for a dyno tune with a cat on in the first place. why not just put a test pipe on (which is cheap) which will help with the flow a lil better too?
^very true but the sniffer method is very accurate enough to see change improvements to the fuel and ignition maps...i have a 2nd o2 bung for tuning purposes and then plug it up with a plug when im done...it takes only 5 mins to plug and unplug the sensor!!!
Using a sniffer pipe will yeald a difference of up to 0,6AFR towards the rich compared to a bung in the pipe just after the turbo. This makes the tune more safe. IE - if you registeruing 11,6 on the tail after a tune at high RPM then your actual AFR is closer to 11:1 at the turbo. Th cat makes a difference though it tends to interfear more at low revs than at high.
I never tune with a sniffer pipe as this defeats the purpose of a clean power tune, but for the mass market - tune-and-go shops this is afast and costeffective method.
A
A
