intercooler questions
Old Apr 14, 2007 | 11:57 AM
evo72man's Avatar
I was planning to upgrade my intercooler to something bigger that would breathe easier before I get it tuned. Does these pressure drops seem normal, would it effect the car idle? Can anyone chime in after upgrading their intercooler?
thanks
length 32''
height 12.5''
inlet 2.5''
outlet 2.5''
compress air flow rate 600 cubic feet/min, rated to 500 max hp
working pressure 35-40 psi
pressure drop 2-5 psi @35 psi, 0.2-0.5 psi @ 15 psi
hot air temperature 32-302
material 100 aluminum
design bar and plate
constructions machine cut and stamped, hand weld
net weight 18 lbs
Old Apr 14, 2007 | 01:19 PM
Q@EvoPowerMods's Avatar
A little off your topic, but you do know that your stock intercooler is good for up to 400hp?
Old Apr 14, 2007 | 01:22 PM
bluebyu36's Avatar
no it will not affect the idle......i run the turbo xs i felt the diffrence in tourqe wright away it's a good mod.just dont use ebay junk...
Old Apr 14, 2007 | 01:27 PM
trinydex's Avatar
what does good for 400 hp mean?
Old Apr 14, 2007 | 01:33 PM
jmoudry's Avatar
I think they are worth it if you live in a hotter climate. Also get upgraded piping to complete the setup. I just had a 24 X 12 X 3.5 core IC with custom piping installed and noticed that it helps with boost taper.
Old Apr 14, 2007 | 01:38 PM
idriveanevo's Avatar
it means it will handle up to 400hp. that DOESNT mean you would be wasting your money if you upgraded. you WILL get more power from a better intercooler
Old Apr 14, 2007 | 01:43 PM
PKEVO8's Avatar
agreed. Make sure to get some new ic piping as well. With a bigger IC you'll get some more turbo lag. The ic piping helps counter that.
mrfred
58
Jan 4, 2016 06:09 PM
sssr20det510
13
Dec 9, 2014 10:39 AM
newcomer81
Apr 1, 2010 07:35 AM
zze86
Jul 26, 2007 03:59 PM
Sgt Blamo
Jun 2, 2006 10:24 PM
