evo green turbo.
Old Apr 19, 2007 | 09:01 PM
PlanoEvo's Avatar
Originally Posted by iTune
What 264 cams? From who? Not all 264 cams are the same. I would go with at least some HKS 272 cams.
I'm actually planning on some HKS 280 cams with a 20g-LT turbo(EvoGreen).
BTW, don't bother buying the extremly over priced upgrade kit for the 20g. There is a thread floating around here with the part numbers of the pieces you need. It will turn out to be about 80 bucks i believe. If you opt to keep your existing coolant and oil lines, they can be bent.
CJ
So is the green upgrade just a new compressor wheel? Or does the compressor housing get enlarged in addition to the new wheel? I've looked and I can't find that $80 kit you spoke of do you have the link?
Old Apr 19, 2007 | 09:31 PM
Kee1pride's Avatar
Originally Posted by dennyt4
I just finished my 9 with the EvoGreen and I'm still on stock cams. Cams really are not required (although they will help flatten your torque out, and give you a little more HP past the 6800rpm drop off of stock), but you really should have more mods than what you listed. Here is my Dynojet results, and my mods are listed after...
Exedy Twin Disk
Forced Performance EvoGreen turbo - ported
Forced Performance wastegate
Buschur ported/coated stock exhaust manifold
Buschur stainless steel coated O2 housing
SMC meth kit
Aquamist DDS3
LC-1 wideband w/ XD-16 A/F gauge
Stewart Warner boost gauge
780cc Injectors
Walbro fuel pump
Injen FMIC
Injen LICP
Injen Upper Pipe
Injen Intake
Forge Unos MBC
TTP dowpipe
Test Pipe
TurboXS cat-back
Good luck if you go with one - I love it
how much boost?
Blue Evo 8's Avatar
Originally Posted by Kee1pride
how much boost?
28-29 PSI I think
Old Apr 20, 2007 | 02:10 AM
dennyt4's Avatar
Originally Posted by ninekrevs
wow those are some sick numbers. Ecuflash? who tuned it? how much boost?
Thanks - it's a lot of fun to drive! Yes tuned using EcuFlash by Nate at TPG Tuning - local Pittsburgh guy. Very good tuner. I'm running 29psi.
Numbers will be a little higher when I decide on which cams I want.
Old Apr 20, 2007 | 02:35 AM
ace75's Avatar
pride, is that with stock head studs?
Old Apr 20, 2007 | 06:54 AM
Kee1pride's Avatar
talking to me? @_@
Old Apr 20, 2007 | 03:07 PM
dennyt4's Avatar
Probably meant for me
Yes stock bolts right now because I didn't trust the 1x1 method after talking to a few trusted people. I will do headstuds once I get cams, or when I blow a headgasket LOL - which will just give me an excuse to get cams anyway.
Old Apr 20, 2007 | 03:55 PM
mikesevo8's Avatar
Here is the list I found on here.
Order the parts from www.mitsubishiparts.net
Quantity Part # Description
1 - 1515A057 Fitting, Air Output
1 - MR281085 Gasket, Air Output
1 - 1310A171 Pipe, Water Return
1 - 1310A248 Pipe, Water Feed
1 - 1225A042 Tube, Oil Feed
2 - MF660063 crush washer
2 - MF660064 crush washer
4 - MF660065 crush washer
They say you can reform (read bend) your old water and oil tubes, but for the price, just buy new ones.
Total price was like $82
What is missing is the gasket PN for the oil return tube on the bottom of the turbo...
Old Apr 20, 2007 | 06:46 PM
sparky's Avatar
Why are we recommending HKS 264, 272 & 280 camsets for an Evo IX? Have the HKS cams for the IX been released yet?
Old Apr 20, 2007 | 07:20 PM
MR. Birdie's Avatar
stop f*cking around and drop some cams in already man.
Old Apr 20, 2007 | 11:05 PM
sparky's Avatar
Birdie: What cams are you running?
Old Apr 20, 2007 | 11:18 PM
MR. Birdie's Avatar
I'm running the GSC S1 cams for evo 9
Old Apr 20, 2007 | 11:21 PM
MONSTARR's Avatar
thread jacked
Old Apr 20, 2007 | 11:23 PM
sparky's Avatar
Externally the Green would be hard to distinguish from a stock IX turbo. It uses the same housings. Internally however, both housings are machined to accept the larger turbine and compressor wheels.
Take the part numbers listed in the above post and buy them at your Mitsu dealer's parts counter.
Old Apr 20, 2007 | 11:35 PM
sparky's Avatar
Originally Posted by MONSTARR
thread jacked
I guess that in a strict, narrow sense, you could claim a 'Jack. However, if you go back and reread the original post, you'll notice the question about cam selection for a IX with an EvoGreen turbo. Birdie has a IX with upgraded cams and an EvoGreen and lists his Dyno numbers in his sig. So, exactly how big of a 'Jack do you consider it to be?
