boost problem after tubo install
i just installed a BR35r and after i went to tial's page for the wastegate install i routed the the vac hose from the top of the wastegate to the bottom of the MBC and to the Intake Manifold. the nipple off the side of the wastegate is running to the side of the MBC. when i turn the car is at idle the wastegate is open and dumping air through the dump tube. when i'm trying to put the car in boost i only get about 3 psi. any ideas of whats wrong??
second - put the boost source from the turbo - to the MBC and then back to the bottom port of the gate
On street cars you dont use the top port on the gate
Its odd that you only make 3 psi - if the gate is open at idle the gate is not installed properly or is stuck open
Al
galantman03
43
Feb 5, 2017 09:54 PM
Mooshu1221
15
Jan 6, 2005 06:43 PM
