518whp@93oct & 625whp C16 EVO 9
It works quite well, as a matter of fact, I even can send you the map I used for the 518 pump gas so you can have a good start!
So how safe is the tune, what is the humidity like down there, elevation also? I am in Hawaii and only have 92oc available. How much boost was used, and what size injectors?
You forgot a few things.
Stock fuel system? Stock ignition? Stock tcase/tranny? Hows everything holding? I thought the ignition system was gone past 500whp basically. Same with fuel.
El carro esta lindo, now my question is, where in Puerto Rico is that car? I'm from Rio Piedras.... I might go to the island for a quick visit and I would like to see the car if I could! Take care!
stock ignition but it needs to be upgraded ASAP, fuel system consists of double walbros in tank with line -10 and AMS fuel rail with aeromotive regulator and presicion 1000 injectors!
