Is this a sign of piston ring?
Old Apr 27, 2007 | 02:12 PM
evovin's Avatar
This is the 2nd time i added oil since two weeks ago. I just change my oil at the dealership 2000miles ago. at first i added i quart of oil after 1200miles the oil change. and today i check my dipstick and saw it is low again so i added half a quart again. I went to track last week. Total of 7 runs since change oil on the 1/8 mile track. Do i really need to replace my piston ring at this moment? or wait and get a srtoker. I might be wrong....i dont see any sign of leak though!
Old Apr 27, 2007 | 02:16 PM
evovin's Avatar
^wrong forum please move
Old Apr 27, 2007 | 02:27 PM
evovin's Avatar
help....anyone!....
car is running perfect but its low in oil for every 500miles i have to put half a quart i gez...
Old Apr 27, 2007 | 02:28 PM
petey pab's Avatar
do a compression test. you will find out that way.
Old Apr 27, 2007 | 02:30 PM
hotrod2448's Avatar
Does the car smoke at all? Just because it is burning oil doesn't necessarily mean your rings are worn.
evovin's Avatar
^ What is the right compression for stock block?
Old Apr 27, 2007 | 02:31 PM
evovin's Avatar
yup! it smokes black @ 93 octane and a little bluish when i use 112 octane!
Old Apr 27, 2007 | 02:36 PM
petey pab's Avatar
i believe its around 180 or so.
Old Apr 27, 2007 | 02:37 PM
smokedmustang's Avatar
How is the turbo?? Could have "Play" and you are having some blow-by from the turbo. How many miles on the car? You first owner? Smokes black can mean running rich. It is tuned right?
hotrod2448's Avatar
Well,
Black smoke= rich
Blue= oil.
You could have been running too rich and washing down the cylinder walls killing the rings, or could be valve guides, turbo seals...
Old Apr 27, 2007 | 02:48 PM
evovin's Avatar
35000 miles. 2nd owner. yup not yet tune coz i was waiting till i get the hks 280's and alky kit.... u think i just need a tune?
Old Apr 27, 2007 | 02:53 PM
The lack of tune explains the smoke, not the oil loss. It might be blow by (Oil is passing the cartridge in the turbo) and blowing out the tailpipe. Do a compression/leak down test. that will tell you if it is in the pistons. Ever had the head off?
Charlie_B's Avatar
A tune is not gonna stop the oil from leaking. But you probably do need one.
+1 on the compression test. I thought the factory specs were around 160... As long as they are close to each other, and not too low, rings should be okay. Do a search for compression readings. People are getting numbers from 120-200. I wanna say mine were all in between 130-132. But Im at high altitude, and I think that affects it.
Old Apr 27, 2007 | 03:05 PM
evovin's Avatar
Thanks to all that responded here...i will check my compression and will get tune as soon as i get my tactrix cable from the mail.
Old Apr 27, 2007 | 11:48 PM
Evo_SpeedKing's Avatar
thats ALOT of oil. first off, lay off the boost. esp. if you don't have it tuned! next, do a compression test first, then if your #'s vary from cyl to cyl (should be around 150-160 across the board) do a leak down test. that will help you narrow the problem down.
