12V Power under the hood?
I am trying to find a 12V source under the hood that comes on/off with the ignition key. I checked the fuse/relay box already and the Mitsubishi site has been unavailable recently.
Thanks,
Eric
Thanks,
Eric
I'm looking for the same, though not for stereo-related goodies. I was just about to break down and go into the cab for it. I didn't see the ignition relay, but will now go back and look again. Anyone have a suggestion on how to wire into it though? Can't really just remove it - can you get access to the wires under it?
-N
-N
Thanks for the reply, no stero stuff here either, I wired up my wide band O2 sensor and the control unit mounts under the hood. I also now have an oil temp gauge, to compliment the EGT and boost gauge, let the games begin.
I did not exactly find the relay you mentioned but I was able to finally remove the bottom cover of the relay/fuse box. There was a nice 6-8 gauge wire (blue with white stripe) that comes on and off with the ignition (probably connected to the relay you mentioned. I added my own relay so as not to tax the power for whatever that is.
To get the bottom cover off I shoved peices of tywraps into the plastic releases and then wrestled with it for awhile.
Hey Mister2zx3,
I met your buddy Larry over at Alamo on Saturday, nice guy. I stopped in to get some Motul, and he happened to be there, we talked for quite awhile and he even let me drive his car. I was very impressed with the car, I am planning similiar mods in the near future, driving his car definitely inspired me (not that I needed it but...).
We will have to go Ranching soon.
Eric
Hey Mister2zx3,
Eric
Larry is a real cool guy. Once he gets the darn fuel tuned in he should have another 30 whp. But his ride is fun, huh? You two actually live real close I am guessing. He is up in Euless.
He has his coil overs just sitting at home. He's waiting to run some laps before he installs them to get a good comparison.
Did he have his silencer there to see the difference between the exhuast note with and without it?
