smell something burnt everytime i hit boost
Old May 13, 2007 | 03:34 PM
deegaw11's Avatar
ok everytime i hit the gas i can hear an exhaust leak but for some reason at night i dont hear it as much, so now whenever i hit boost i always smell something burning afterwards. it would smell really burnt, does anybody know where this leak might be coming from? i started getting this leak after i put on a TBE.
Old May 13, 2007 | 03:37 PM
idriveanevo's Avatar
did you put the donut gasket back on the o2 housing? sounds like you just have a exhaust leak...
Old May 13, 2007 | 06:18 PM
deegaw11's Avatar
no donut gasket because buschur's dp doesnt use it, so if you WOT with an exhaust leak u get a really nasty burnt smell after?
Old May 13, 2007 | 07:34 PM
JordanS4's Avatar
are you sure it's not clutch? is your clutch slipping? if not, it sounds like at WOT when the engine torques back something hot like a DP is touching something else and burning it.
Old May 14, 2007 | 05:38 AM
dxbevo9's Avatar
i smelt the same thing after i installed my O2 housing...found out that its the O2 sensor wire that goes into the O2 housing...make sure no wire is touching anything that gets really hot.
good luck
