New Evo...NEED HELP
Old May 14, 2007 | 05:32 PM
I Kill Suckers's Avatar
New Evo...NEED HELP
Hey guys...Well I picked up a 05 Evo8 GSR used a couple weeks ago and have some questions. The car has a HKS RS intake, 280 cams, Ebay 02 housing, ams motor mount inserts and i belive aWalbro FP.. Ok here are some pictures of the turbo, is this a adjustable wastegate? Also i just installed a Apexi EL2 boost guage and when I drive I am only at .8bar... And I know that is very low...lol...So I was wondering if there could be a boost leak that would make it this low, and if so where are the most common places for one. I have already zip tied the majority of the vac lines. I am pretty much out of ideas. PLEASE HELP....
http://viewmorepics.myspace.com/inde...mageID=5610774
http://viewmorepics.myspace.com/inde...mageID=5610786
http://viewmorepics.myspace.com/inde...mageID=5610821
Old May 14, 2007 | 05:37 PM
Wallesasuaz's Avatar
Is there a Boost controller installed?
Old May 14, 2007 | 05:47 PM
no....but the previous owner definetely had one because there are 2 T;s that are capped off..
Old May 14, 2007 | 05:48 PM
Old May 14, 2007 | 05:53 PM
since you said you hooked up your lines already. Make sure u have your lines hooked up properly.
Definitely a boost leak.
Old May 14, 2007 | 05:58 PM
jrsimon27's Avatar
the lines most not be hooked up properly check that first
Old May 14, 2007 | 06:33 PM
spdracerut's Avatar
0.8 bar is ~11.6psi... sounds like you're running wastegate pressure. You can search and read about it
Old May 15, 2007 | 12:38 PM
alright im going to check all the lines and the piping clamps
Old May 17, 2007 | 03:08 PM
didnt work, mayb i juss missed 1....but we looked everywhere and zip tied everything..lol....I'm Lost
EvoDom
Apr 10, 2009 09:12 PM
S13 Curtis
Apr 3, 2009 10:07 AM
@SD EVO@
11
Jan 28, 2009 08:09 AM
03redtype-s
Apr 19, 2007 10:13 PM
