trouble getting into 3rd gear
Old May 16, 2007 | 10:35 PM
Steiner's Avatar
Recently I installed a WORKS shifter, base bushings and underhood bushings. Since that installation I'm having a helluva time getting into 3rd gear on occasion. It's like I hit a wall. I have to double clutch it and try again. I've read plenty of 3rd and 5th gear synchro war stories but, since the problem only started after replacing the shifter and bushings, I'm wondering if there's some other issue that just has that same type of symptom. Any ideas?
Old May 16, 2007 | 11:07 PM
RazorLab's Avatar
You need to make sure there is no binding in the cables and adjust if needed.
Old May 17, 2007 | 08:31 AM
Steiner's Avatar
Should I start under the hood, in the console or both? Also can you describe what you mean by binding?
Old May 20, 2007 | 07:39 PM
Steiner's Avatar
I've set some time aside today to work on this. It's getting really frustrated. I'm starting to think it's just a coincidence that it all started after replacing the shifter and bushings. I'm now scared it really is a synchro. If it was a kink in the cable or something related to the bushings or shifter, wouldn't it do it all the time? It doesn't do it all the time though...just when I'm aggressively shifting from 2nd to 3rd.
Old Jun 16, 2007 | 12:24 PM
Steiner's Avatar
bump
Old Jun 16, 2007 | 02:03 PM
yikez's Avatar
did you change ur clutch recently? change adjustment of clutch pedal?
If so you need to adjust ur clutch pedal again, im guessing u are having a lockout at high rpm shifts
Old Jun 16, 2007 | 04:11 PM
Steiner's Avatar
I'm on the stock clutch. I haven't touched anything or made any adjustments to it whatsoever.
High RPM lockout is exactly what it is. Only going from 2nd to 3rd gear though. Even during normal driving the shift feels a little congested...almost like it's rubbing against something.
