305awhp Evo shatters RS diff :(
Old May 17, 2007 | 01:01 PM
  #31
DRFTKNGG's Avatar
Originally Posted by scorke
I'm assuming you don't want to sell just the diff?
Scorke
I would rather sell the complete unit and keep my hands clean....know what I mean.
$1500.00 is a steal for a complete diff considering their arent a whole bunch floating around.
Old May 17, 2007 | 01:02 PM
  #32
smokedmustang's Avatar
Originally Posted by 94AWDcoupe
A local here with a low 12 second car just did the same thing to his ACD t-case. Diff exploded. cracked t-case in half. Bad part was in destroyed his 6speed tranny as well. He admits he revved to 6k and dumped the clutch. Car only had 11k on it. I guess you could say his was prestressed as well. Or that drivetrain parts do break on AWD cars on a hard launch.
I was standing10ft from this car when it "went". No big noise, no high rev launch. Kinda wierd when it let go (he drove 1 foot then nothing). When mine blew on the dragstrip, it popped SUPER loud, and lifted the wheels off the ground almost, then the "black soot/smoke" poured out the vent and fenderwells. Complete opposite here. This guy (broeli) is a road racer, not drag racer as far as I know. Not sure of the history of the TC before he got it though.
Old May 17, 2007 | 01:03 PM
  #33
DRFTKNGG's Avatar
Sorry, are we talking the rear diff or the t case diff?
  #34
scorke's Avatar
Front diff. T Case diff.
Scorke
Old May 17, 2007 | 01:05 PM
  #35
DRFTKNGG's Avatar
I was talking about the reaf diff...
05's and up have the ACD...03 and 04 have the spyder gears also known as planitary gears..
Old May 17, 2007 | 01:10 PM
  #36
Silver05Bullet's Avatar
i did a similiar thing to mine
Old May 17, 2007 | 01:14 PM
  #37
broeli's Avatar
Yep. No big noise at all. It went on a pretty soft launch. My open diff lasted FAR longer. I very rarely drag race with the Evo. As a matter of fact I have not made even one pass at the strip with the RS diff. I launched on it maybe 6 times....all during an autox start with no VHT to help grip. This is definitely an unusual failure.
My open diff went out on me at the strip when I was going to make a few passes at the Cincy DSM Shootout. I very rarely make drag strip passes. Usually only if it is part of an event. My Evo isn't even driven much on the street. It is primarily used for road course racing and autox'ing.
Old May 17, 2007 | 01:27 PM
  #38
EV0lut10n_8's Avatar
i have my stock open diff for sale cheap if you want it, took it out at 10k which was all highway, zero launches on it.
Old Jul 20, 2009 | 12:23 PM
  #39
broeli's Avatar
Well it happened again. Blew my second RS lsd at an autox yesterday Needless to say I'm going with a Quaife
Old Jul 20, 2009 | 05:06 PM
  #40
primetime's Avatar
damn dude you got no luck!
Old Jul 20, 2009 | 07:21 PM
  #41
Evo8Emperor's Avatar
I dont know but it seems that there has to been something else going on...
If not then you definitely got some sh!tty luck. How much did you spend so far on the 2 diffs and a new shell ?
Old Jul 20, 2009 | 10:21 PM
  #42
Appauldd's Avatar
Eli.....get an extra set of shims from Mitsu....you have to set the gear lash correctly. When I installed mine I noticed the LSD was a bit looser than the stock open diff. A few thousands of movement can mean a lot.
I am curious if you are a little too low on your suspension causing the stub axles to bind slightly inside the diff when you launch. Just a hunch.
If you need an open diff to keep the car on the road...I have one sitting in a box in my attic.
Old Jul 20, 2009 | 10:55 PM
  #43
heel2toe's Avatar
Wow i just read this from the beginning and saw the date back in 2007. And then i got to you recent post...I am sorry to hear about this. Good luck with the Qualife diff and I hope you get her back up and running soon!
Old Jul 20, 2009 | 11:05 PM
  #44
xspsi4's Avatar
Something else has to be causing this type of failure.
This is just way to uncommon.
Old Jul 21, 2009 | 12:45 AM
  #45
Levar's Avatar
Veteran: Army
Subscribed. I'm curious as to the post in reference to having a lower suspension. If I'm currently running 25mm spacers on the front could this be doing more harm than good? I now have the Quaife LSD on my to-buy list once I return from Iraq.
CJ2X
Aug 10, 2017 10:35 AM
CJ2X
Dec 2, 2011 11:37 AM
CJ2X
Jan 4, 2011 12:48 AM
Juan Martinez
Jul 30, 2010 04:04 PM
CJ2X
Feb 18, 2010 11:28 AM
