Is there an easy way to tell if you have a fuel pump?
Old May 17, 2007 | 03:24 PM
L80Killa87's Avatar
I bought my evo used and it had some parts on it already. Well I THOUGHT it was a stock tune, but somebody put a crappy flash on it. now I'm wondering if it already has a walbro in it. Is there any easy way to tell?
Old May 17, 2007 | 03:26 PM
derangedazn's Avatar
do you hear a whine...coming from the rear of you car....while completely stopped....if so you might have it.
Or just asked the previous owner.
Old May 17, 2007 | 03:28 PM
L80Killa87's Avatar
A whine? I can check. Will I be able to hear it in the drivers seat? Its complicated with asking the previous owner haha, I dunno who he is. I mean of course I can tear out the seat and what not and pull the unit out, but that would suck lol.
Old May 17, 2007 | 03:39 PM
You know who flashed the car...You might want to check there...some places keep a log of which car they flashed with what mods.
As for the sound of the walbro...some describe it as a whine..other describe it as a low tone drone...coming from the rear drivers side area.
Old May 17, 2007 | 03:48 PM
L80Killa87's Avatar
No clue who flashed it, scott *ttp* REflashed it, he said the flash that was on the car was crap.
Old May 17, 2007 | 03:54 PM
jenx1976's Avatar
you should be able to hear it when idling....sound like a electric motor running......atleast mine does.
Old May 17, 2007 | 04:20 PM
L80Killa87's Avatar
Radio off, windows up/down? I'm guessing its like a high pitch whine almost?
Old May 17, 2007 | 05:15 PM
radio off....windows up...sounds similar to an electric razor
Old May 17, 2007 | 06:19 PM
Ludikraut's Avatar
Walbros don't always whine. Have someone check it. It isn't that hard to get to.
l8r)
Old May 17, 2007 | 07:48 PM
L80Killa87's Avatar
I hear a whine when I rev, who knows if its from a walbro. I don't need anybody to check it FOR ME haha. I just would rather not tear into it unless I have to. But I might as well, better than banking on a whine I can hear.
Old May 17, 2007 | 08:32 PM
KartaRailed's Avatar
Chances are if the bolts on the black tank cover have been turned, you have a walbro, no one takes them out to go back to stock, there cheap as hell.
Old May 17, 2007 | 08:37 PM
L80Killa87's Avatar
Thats what I was thinking, pull the cushion and examine the bolts. I have a HUNCH that I have a pump, which would be awesome, save myself 90 bucks.
Old May 18, 2007 | 01:13 AM
riceball777's Avatar
with your car running stick your head by the driverside wheel. if you hear a whining sound youhave a fuel pump
Old May 18, 2007 | 06:35 AM
Charlie_B's Avatar
I was in the same position. Except I didnt find out I had a fuel pump until I went to put a new one in. Now Ive got a spare sitting on the shelf. Id probably just take the rear seat off. Crank the car, and put your ear next to the driver's side panel under the rear seat, and you should hear it. While there, check for turned bolts (as stated above).
Old May 18, 2007 | 06:45 AM
mudduck's Avatar
At idle, listen for an electric whine - then - with both windows already up, pull up on the window buttons briefly - this puts a strain on the car's electrical system, and will cause the Walbro's whine to change its pitch.
Note: this won't work if you have an aftermarket audio amplifier - will also whine...
Okay, just pop the back seat out already...
