how to get 400whp with 20g?
Old Jun 16, 2007 | 11:33 PM
  #31
Devil_Evo's Avatar
get a tune first
Old Jun 17, 2007 | 07:07 PM
  #32
darqnez's Avatar
That RSR has a taper nearly down to 2 1/4 in it, get rid of it and get a tanabe touring medallion, no taper and just as if not quieter, also get a rre rally cat, its a resonated test pipe that is super quiet qhile being straight thru
Originally Posted by slowevo4u
im running:
20g turbo
rsr catback exhaust
rsr downpipe
megan O2outlet
hks intake
and im making 346whp and 342trq on 95oct
i have licp on the way.
Old Jun 17, 2007 | 08:44 PM
  #33
sparky's Avatar
Originally Posted by Joshs EVO
OK so I just picked up my 20G and I was thinking I was going to be able to get over 400 with just the turbo and my supporting mods. I currently have:
Hks 272
AMS IC, LICP, UICP
Invidia TB exhaust and downpipe
HKS Intake
AEM cam gears
Perrin MBC
XS Power exhaust manifold
and now my 20g.... So am I going to get above 400 or not.
Are you talking about the BR 20G-LT specifically and producing 400WHP on pump gas? I think that it would be wise to upgrade your fuel system with a 255 LPH Walbro fuel pump and a set of larger injectors(might as well go 750's or bigger). Do an O2 housing upgrade as well, to compliment your header, turbo and full TBE. Meth(not, however, U.S.P. methedrine) will make it easier to reach your desired goal.
Old Jun 18, 2007 | 03:46 PM
  #34
Joshs EVO's Avatar
Ya i have th fuel pump also just forgot to add it. I bought the car from a guy and I guess it has a ebay o2 on it. The bigger injectors are on the way soon.
Old Jun 28, 2007 | 07:12 PM
  #35
Joshs EVO's Avatar
bump
Old Jun 28, 2007 | 07:27 PM
  #36
NewEvolutionIX's Avatar
Try getting a tune or I hear Vishnu's ECU Reflash works, its 380v reflash is 380 horse power to the flywheel with just the reflash. And if you have more mods which you do have, they tune it to what you have on your car. Try checking them out!
Old Jun 28, 2007 | 09:19 PM
  #37
inco9nito99's Avatar
boltons + cams + 680cc + 102octane + 23psi...I tuned it and did 400awhp/400awtq on my friend's car, rough conservative tune -relatively simple.
Old Jun 30, 2007 | 03:19 AM
  #38
slowevo4u's Avatar
ok so im back...been gone for a while...i now have the following:
20g
rsr turbo back exhaust
megan o2 outlet
255 walbro fuel pump
cosworth 272 cams
rc 750cc injectors
halman mbc
injen upper and lower icp
hks intake
will i hit my 400whp mark? any other suggestions before i get it tuned. i heard that if i put and exhaust cam gear i might be able to pull a few more horses? is it worth it?
Old Jun 30, 2007 | 04:21 PM
  #39
LayinLo's Avatar
You shouldn't need the cam gears.
Old Jun 30, 2007 | 04:28 PM
  #40
VenomEVO8's Avatar
boost at 23 or 24... cams, and meth.. be over your 400 whp..
I put 350 down on stock 16g,licp,uicp,fmic and 9.8 hotside.. !!
Old Jul 1, 2007 | 02:02 AM
  #41
slowevo4u's Avatar
cool...i'll keep u guys posted for when i tune in a couple weeks...just waiting for the day
Old Jul 1, 2007 | 03:26 AM
  #42
Erik@MIL.SPEC's Avatar
Is the 20G you're talking about the EvoGreen? Because if it isn't you're not going to get that 400whp on a Dynojet number.
With all my bolt-ons, I am hoping for 330whp on a Mustang Dyno on 91 octane. Now, this would be about 10whp more than other EvoGreens on 91, but I have every bolt-on conceivable (short of engine work). Don't know if I can hit that number, but it's good to have a goal
Old Jul 2, 2007 | 01:17 AM
  #43
slowevo4u's Avatar
unfortunately it's not the green..i f****d up buying the turbo...so im crossing my fingers for any where around 380-400whp..right now im pushing 346whp 344trq on 100oct tuned for 91 on a conservitive tune...so hopefully when i tune for 100oct aggressively it'll be close
Old Jul 2, 2007 | 08:40 AM
  #44
El.BlueEvo9's Avatar
Mine dynoed 430WHP and 420TQ with stock cams.
Old Jul 2, 2007 | 06:01 PM
  #45
backcountryGSX's Avatar
Go with the GSC S1 cams with a custom tune and you'll be close to 400whp
