WTF cant boost past 25 psi HELP
Old May 24, 2007 | 05:07 AM
sparky's Avatar
Are you still on the 9.8 HS?
EvoDan2004's Avatar
Guys. I pulled the waste gate line to run max able boost. No change. The eliminates mbc problem no????
Preload on the waste gate I'm sure if fine. I used to run 27 28 psi on 100 oct befor I got meth. I did not mess with anything other then add meth. So I'm sure its fine. But I will check and report back
Old May 24, 2007 | 02:17 PM
EvoDan2004's Avatar
no i have a ported 10.5
Old May 24, 2007 | 02:19 PM
EvoDan2004's Avatar
You might wanna get an idea of just how much preload you are running on the WG since it won't cost you anything and just takes a minute to try.
The easiest way is to just to turn your MBC out , counterclockwise, all the way to fully soft(as far as it goes), and take it for a WOT run.
did it
heavy spring inside mbc
red 19 too 24 psi spring inside forge waste gate
car boosted 15 to 16 psi in 3rd and 4th gear. eww
so im making it tighter. see if this works.
Old May 24, 2007 | 03:05 PM
EvoDan2004's Avatar
ok well the waste gate with 19 to 24 psi spring in side is as damn tight as it can go. i cant get boost past 17 psi. 18 at most. man wtf. so now ill turn up the mbc and see what it does.
Old May 24, 2007 | 05:01 PM
EvoDan2004's Avatar
Ok problem fixed. 1st pass out 32 psi daaaaaaaamn I said. Now I'm starting to tune on 27.5. Ill see where it gos. Thanks mostly to sparky for helping out. Damn bro I never would of thought it would work that way. Yo thanks so much
OK PROBLEM IS BACK. HAHAHAAH
Old May 24, 2007 | 05:26 PM
e2swing's Avatar
What ended up being the problem? Just curious, I'm having problems getting past 30psi.
Old May 24, 2007 | 05:38 PM
Ph3n1x's Avatar
This is so lame....he posts everything and then couldnt say how he fixed it
Old May 24, 2007 | 06:26 PM
hotrod2448's Avatar
I believe adjusting the wastegate was what fixed it.
Old May 24, 2007 | 06:39 PM
EvoDan2004's Avatar
wow relax all. lol
yes the waste gate was running 15psi. wtf. so i did as sparky said and set it to as high as i can go up to 21 psi. well i can only get 18 psi out of it. but still the car is boosting wild now. my 1st log was 31 psi. ooops. i am starting my tuning on 27 psi. take it from there.
my probem was not knowing my settings on my waste gate. and not knowing out to ajust it. now i know and next time i hope to help someone else
Old May 24, 2007 | 06:47 PM
Ph3n1x's Avatar
Ok so not enough preload. cool future searchers will understand and learn from this.
Old May 24, 2007 | 08:17 PM
scottatyamaha's Avatar
ok i dont get any props for telling you first....thanks..
Old May 25, 2007 | 02:51 AM
EvoDan2004's Avatar
Lol oops I 4got yes your right you get mad props dogg but sparky gets mad er props lol. We spoke through pm and a few other things. Thanks again to EVERYONE lol
Old May 25, 2007 | 09:33 PM
EvoDan2004's Avatar
Ok problem is back my settings are the same when the problem was fixed. Now tonite its back to peak 25 psi. I hate my life
Old May 25, 2007 | 09:54 PM
sparky's Avatar
Can you do a complete and thurough list of your mods for our info please? Neither your 10.5 hotside nor your MBC are included in the list. Do you have any other mods which aren´t listed? Is there any ECU tuning? Have you done any mods to the exhaust or the intake? Are you running the catalytic convertor and the complete factory exhaust? Do you have an air filter mod or a Walbro fuel pump?
Last edited by sparky; May 26, 2007 at 08:59 PM. Reason: correction of spelling errors
