Help, I cant get the tranny out of the car
I have the t-case separated and all of the bolts out of the tranny, but it wont slide out more than an inch. And then it feels like it gets stuck. The clutch fork is towards the passenger side of the car. Did I miss something. I have been trying to wiggle it out for hours now. It isn't contacting anything, it just wont slide all the way out.
any help would be appreciated
This is what it looks like through the lower inspection hole
Do I still need to separate something?
Yes make sure pull Shaft out of tranny that connected to the front axle.....With the transfer case dicconneted should only have neen 3 or bolts up top and one front of car bottom holding it.....
It has like dowls so may some persuading to come apart......Make sure your wedgecollar is separated should be good....I used a pry bar carefully to seperate....
I am sure u are using the write ups by joe and evomoto if not do search for transmission install by joe....over 200 post of good info and links
thanks
you need to pop it off something..my friend and I used a long thin prybar with a 45deg. angle at the end.. you will hear a snap/pop kind of sound when it releases. I had to turn the crank a few times until he found the spot to pop it off.
Your throw out bearing is not released from the wedge collar most likely. You can tell if you look through the bottom inspection hole and when moving the fork it is not moving anything on the clutch.
Did you use the how-to at evomoto ??? Great pics.
When I look through the inspection hole it looks like the wedge collar and a few wave washers are loose in there. When I move the fork back and forth it looks like the tob is still attached to the fork. Is that what needs to be separated?
I can push the fork back and forth, but it will only go to midpoint of the slot. It wants to stay on the passenger side, but I can push it towards the driver side, and it springs back to the passenger side.
Yes, there are springs inside.
If you haven't already - go to the www.evomoto.com website, and find their excellant write-up for installing a clutch in the Evo Tech section.
