Spark plugs for Evogreen?
Old May 25, 2007 | 02:25 AM
Jspec EVO VIII's Avatar
Well i'm looking into changing plugs along w/my full tune up. Should i grab a set of stockers or should i upgrade to something like the NGK iridium BR8EIX? Looking if i should upgrade as well for the evogreen i have on.
Old May 25, 2007 | 02:52 AM
vboy425's Avatar
you have an 8. get BPR8ES or BPR7ES. Copper put out better sparks, but don't last as long as the Iridium overprice ****. Plus gap them to like .024mm-.022mm
Old May 25, 2007 | 03:56 AM
TeStUdO's Avatar
That is too small of a gap. .026-.028 is more like it.
Old May 25, 2007 | 11:45 AM
Kee1pride's Avatar
agreed on .26-.28
Old May 28, 2007 | 02:10 AM
8UpUrV8's Avatar
jestr recommened .024 for full bolt on w cams
Old May 28, 2007 | 05:48 AM
sparky's Avatar
Try the NGK BR7ES's, which heat-wise are between BPR7ES's and the BPR8ES's. Gap them at .024-.026". Or use the BR8ES. The BR7ES should be an o.k. plug for the street. If you're gonna be running a lot of boost, then go for the BR8ES's.
I personally run the BR8ES in daily street/highway, low boost, driving and they haven't fouled yet at 3000 miles. Also, my buddy RSimon who does extensive knock logging at high boost levels, loves this BR8ES plug.
The BR series plugs are considered less detonation prone than the BPR series plugs, because they(the BR's) have a non-protruding tip. The protruding tip of the BPR plugs is seen as potentially more likely to preignite the combustion chamber mixture. Additionaly, because of the non-protruding tip, the BR plugs, run a half heat range colder than their numerically equivalent BPR counterpart.
Old May 28, 2007 | 06:13 AM
Thanks guys for all the responses. Should be going in the shop for a quick tune up after i hit the track within the next 2 weeks.
