Is it bad to change your oil real often?
Old Jun 24, 2003 | 04:55 PM
timzcat's Avatar
Engine oil viscosity is determined by clearances and orifices. Thicker oil can and will cause problems in areas like lash adjusters as the bleed holes are designed for thinner oil.
Old Jun 25, 2003 | 06:31 AM
silverEVO8's Avatar
Originally posted by 2Cool
Let me quote a bit from the "Warranty and Maintenance Manual:
Seems cut and dried to me. use what you wish if you do not want a warranty, otherwise use 10W-30 fully synthetic.
I think you are right, it's cut and dried. Besides what would be the advantage of changing the oil anyway? I guess any fully synthetic oil of the appropriate viscosity and the correct specifications will work just as well but Mobil 1 is easy to find and can be gotten at relatively good prices so I don't see a good reason to change.
FWIW, Mobil 1 has been the oil of choice for many manufacturers as well as for lots of folks out there too. It is interesting to know though, that Subaru does not recommend the use of synthetic oil in the WRX! They do not object to it, but they do not recommend it either
Old Jun 25, 2003 | 07:14 AM
boostedwrx's Avatar
Yea the subies are die hard Dyno oil... freaks...
in my subie I used Amsoil New Car forumula which is a Syn/Dyno blend until 5000miles where I switched to Amsoil 10w30.
I havent aten a DROP of oil in my EVO since my last oil change (1000miles ago). This is AWEASOME! I have been driving it pretty hard too. I think its sealed up and won't eat a drop the rest of its life (hopefully!) BTW - im still using Amsoil 10w30 in my evo...
Old Jun 25, 2003 | 01:21 PM
Event-Horizon's Avatar
well in the service manual it says:
Engine OIL
Fully synthetic engine oils displaying ILSAC GF-3 certification symbol ("Starburst" symbol) or conforming to the API classification SL or SL/CF
it also says that you can use SAE 20W-40 for temperatures 32F and above and SAE 10W-30 for -10F and above.
not sure where to get 20w-40 though.
Old Jun 25, 2003 | 04:18 PM
SOF's Avatar
SOF
Oil viscosities are determined at the molecular level. Are you telling me the engine clearances are on the factor of microns?
Old Jun 25, 2003 | 05:11 PM
timzcat's Avatar
No you misunderstood.
The manufaturer of the engine determines what oil viscosity they will be using in the engine and then design based on that.
Old Jun 25, 2003 | 05:23 PM
evoinit's Avatar
i thought we were supposed to use 5w30 in the evo's
Old Jun 25, 2003 | 05:37 PM
well, 5w-30 is mostly used for very cold climate areas the majority of the time. However, I do not understand why the service manual and the users manual contradict one another. Correct me if I'm wrong, but dont heavier weight oils (mostly syn) hold up to heat better? Maybe its better to use heavier oils in the evo.
Old Jun 25, 2003 | 07:36 PM
SOF's Avatar
SOF
Originally posted by zlancer
good choice!
I agree. Even Ferrari uses 10W-60.
Old Jun 26, 2003 | 09:12 AM
boostedwrx's Avatar
maybe ill switch to 10w60 when my warranty is expired!
Old Jun 26, 2003 | 10:02 AM
silverEVO8's Avatar
While it's true that several degrees of viscosity can be safely used in most motors, it's good to remember that there are differences in the way engines are designed and built... Ferrari might use looser tolerances or clearances in some areas than uses in the EVO. Heavier oils can have negative effects because they do not flow as readily and could cause some parts of the engine to run without proper lubrication while the heavy oil flows through all the passages and clearances....
Just my $.02
Old Jun 26, 2003 | 03:20 PM
boostedwrx's Avatar
daaaaaaaaaaaaaaaaaaaaaaaaaaaaamn
10w60 is expensive....
Cladius - I have not aten a drop of oil since my last change, about 700 miles ago. I think the amount of oil consumed was part of the normal breakin; hence Mitsu filling up the pans .5 quart over.
Old Jun 26, 2003 | 09:31 PM
Sunder's Avatar
I'd stick to 10w30 as well...
A 10w60 is thicker, so even if nothing else goes wrong, you'd lose a few horses... If you didn't care for those few horses, I'd still be worried about flow characteristics when the engine is revving high. Can it get everywhere it needs to?
Old Jun 26, 2003 | 10:23 PM
boostedwrx's Avatar
I dont think 10w60 is a heavier oil per say, its a multiblend and not just a solid 60 weight. Correct me if im wrong someone
