Bad lifter, Rod Knock, or Bent Valve (Video)
Old Jun 3, 2007 | 10:19 AM
The.alibi's Avatar
I have never heard the sound before, if anybody can give me a bit more insight before i pull everything apart i'd appreciate it.
Old Jun 3, 2007 | 10:23 AM
Thegame's Avatar
I don't think that it's in the valvetrain. I have never heard anything like that before either. Before tearing everything down, a compression test may be helpful to determine if it is indeed in the head. Do you have any CEL's or power loss?
Old Jun 3, 2007 | 10:24 AM
idriveanevo's Avatar
from the vid, i would say a rod
Old Jun 3, 2007 | 10:25 AM
bluebyu36's Avatar
sounds like's the motor.....do a compression test
+1 on the rod
i think it's time to do rods and pistons
Old Jun 3, 2007 | 10:29 AM
The.alibi's Avatar
No CEL's, there was no power loss either, but then again once i heard the sound, i didnt push the car anymore
Old Jun 3, 2007 | 10:35 AM
smokedmustang's Avatar
Rod knock, you spun a bearing. Don't do that any more, or you will have a rod blowing out the side of the block. I spun a rod bearing, and it sounded just like that!! The more you run/idle the car, the more you are sending the copper/brass shavings (Rod bearing material) thru the motor and head, causing more dammage. Sorry about your mis-fortune bro.
Old Jun 3, 2007 | 10:56 AM
The.alibi's Avatar
Such is life, gotta pay to play
Old Jun 3, 2007 | 12:55 PM
JMB8606's Avatar
+ 1 with a spun bearing. Chech ur oil is probably very low
Old Jun 3, 2007 | 01:00 PM
EMonz57's Avatar
Id have to say bearing as well. def dont run the car anymore or youll be paying for a turbo and head as well.
Old Jun 3, 2007 | 02:57 PM
nos51's Avatar
rod knock.......pull it apart see what you got left
Newfoundlancer
Apr 25, 2007 06:23 PM
The.alibi
Dec 12, 2006 02:30 PM
The.alibi
Nov 10, 2006 08:08 AM
The.alibi
Sep 16, 2006 12:40 PM
