9 in 8
Old Jun 10, 2007 | 04:31 AM
EVOL2003's Avatar
9 in 8
what is all intailed with puttin a 9 turbo setup into an 8?
does it just bolt on? then all i have to do is get another tune?
Old Jun 10, 2007 | 06:04 AM
EVOL2003's Avatar
anyone?
Old Jun 10, 2007 | 06:09 AM
kaonashi's Avatar
from what ive seen, it looks almost exsactly the same with the exception of the turbo outlet is different but not too much all you need is outlet really
this is my Evo 8 turbo next to FP green
Old Jun 10, 2007 | 06:12 AM
EVOL2003's Avatar
yeah a bigger hotside....and then just a retune right?
Old Jun 10, 2007 | 07:04 AM
Warrtalon's Avatar
Um, maybe a few minutes searching? This has been covered many times with all the information readily available. No, the difference in the IX turbo is not 'a bigger hotside."
Old Jun 10, 2007 | 07:14 AM
EVOL2003's Avatar
yes i relize that is not the only differance....i was hopin you would be more of a help like u usally are...^
Old Jun 10, 2007 | 07:42 AM
Jim in Tucson's Avatar
EVOL2003,
I just did this recently, sort of. I actually upgraded my '03 VIII to an IX turbo, a SS eBay O2 housing (yes, the right one), and a PPI ported exhaust manifold (thanks Wayne) all at one time. Followed up by a fresh tune.
All you really need is the turbo outlet - Mitsu # 1515A057 "Fitting, Air Output" $37.91. However, being **** I ordered the entire IX turbo swap kit from EvoM member "Spins4".
Now for the bad news, all three of the added mods netted me 15hp and no torque. I will admitted I was bummed. Was it worth it? No. However, I have more mods planned so this was a sort of stepping stone that I can live with.
I'm probably limited to a great extent by the lousy ACN91, which I understand to be worse than the 91 elsewhere in the country. If you are on 93 or 94, I'm sure the IX turbo would give better results. Certainly meth or alky would also make a difference.
YMMV...
Old Jun 10, 2007 | 10:00 AM
EVOL2003's Avatar
thanks man^
Old Jun 10, 2007 | 10:02 AM
Warrtalon's Avatar
I did this upgrade and posted an entire thread reviewing it specifically so that people like you would have the information and not need to post new threads asking the same questions over and over. If you had searched, you would have seen that thread and many other threads. Make sense?
Scottr126
Nov 19, 2012 09:27 AM
rocknsnoboarder
Northeast Region
16
Mar 7, 2010 01:25 PM
playmajohn
May 22, 2008 07:12 PM
Trustz
11
Feb 22, 2006 09:31 PM
