loss power after cam install
Old Jun 15, 2007 | 08:11 AM
  #31
RedLanEVO's Avatar
Originally Posted by kjewer1
I thought it was already mentioned in this thread, but have you double checked the CAS trigger orientation? Mine ended up being 180 degrees off. I think I know how that happened, but it's a long story. At any rate, the HKS 272s that I swapped back in for testing purposes didn't seem to mind much, the car went nearly 122 on the EVO Green. The revolvers straight up went 115 with the CAS trigger out 180, and 120 with the CAS trigger flipped to it's proper orientation. 5 mph gain or lost there on the Revolvers, which seem to be more sensitive to it than the HKS. I don't know what the HKSs would have run with the CAS fixed, but I don't feel that it would have been much more than a 1-2 mph difference (no way to know now though).
Worth looking into, if you haven't already.
yep, that sensor is in the right position. it was the very first thing i checked. thanks though! according to the manual, when the piston #1 is at TDC, with all cam marks aligned, the sensor's smaller vane should be pointed northwest looking at it from the driver's side fender. that is how mine is, if i am wrong, please tell me so!
Old Jun 15, 2007 | 11:43 AM
  #32
kjewer1's Avatar
Yup, the bigger portion occupys the space between 3 and 6 oclock, roughly.
Old Jun 16, 2007 | 07:56 PM
  #33
RedLanEVO's Avatar
i guess i'll get it tuned and see what happens. thanks everyone
Old Jun 16, 2007 | 09:49 PM
  #34
evovin's Avatar
Paul is not running Buddy club cams 272's! He has Brian Crowers 280's!^^ look at the guys sig...
Originally Posted by JohnBradley
Not being tuned isnt helping, but trust me with the Brian Crowers the lobecenters are too tight and there is alot of power to be found. How much? How about 9% or so. Paul's (Ifarted2) car went from 650whp to 700+ with cam gears and altered cam timing. Its not like I havent built a few motors or engineered a few cams in the last 15 years.
But hey what do I know, all of you guys seem to have the advice dept. covered.
Old Jun 17, 2007 | 03:48 PM
  #35
JohnBradley's Avatar
His sig has recently been updated? In the initial post it just says BC 272's and the only cam I have ever called BC is a Brian Crower. Buddy Clubs are typically just referred to as "Buddy Clubs".
Buddy Club 272's dont seem to have the specs anywhere I can find them. I shouldnt have jumped to the conclusion that they were Crowers in any event though. RedLan do you have a cam card with these cams? That would go along way in us figuring out some likely cam gear settings and maybe getting it running better.
JB
Old Jun 17, 2007 | 06:31 PM
  #36
RedLanEVO's Avatar
JB
you know what? i don't have cam cards with these cams. what to do? i heard they were exact same specs as hks 272's though. am i right? if these cams give me a hard time, i might just have to jump to 270 tomei procams since i have the upgraded valvesprings and retainers already
sorry john, i meant buddyclubs. BC's? i thought it was short for buddyclubs. i didn't even think about brain crower cams and how it can get mixed up!
Polov93
Jul 22, 2016 06:17 PM
beasters
Oct 30, 2014 04:01 PM
clanzkiller
24
Jun 15, 2014 03:33 AM
PERRIN_JOHN
24
Apr 23, 2009 11:01 AM
