NEW Product Release: AMS Drag Rear Differential Setup
If you make over 700 whp and you haven’t blown up a rear diff…you will. AMS has your solution. After lots of research and development we have discovered a differential setup that will hold up to the most brutal conditions.
The AMS rear Diff includes the following:
- A bigger and stronger ring and pinion
- A much larger Pinion Shaft diameter
- Specifically designed to incorporate custom Stage 5 Driveshaft shop axles
- Large Axle cups incorporated into the differential
- Solid mount design to eliminate any loss in torque
- Bolts directly into the factory location using AMS engineered differential mounts
- Allows for the removal of the Moustache bar, a 13 lb savings
- Retains the stock gear ratio
This is a must for all cars that are looking to cut a sub 1.5 sixty foot or looking into making an excess of 700 WHP!
Available soon from AMS!
Thank you
Rich K.
Marketing Director
AutoMotoSports Inc. (AMS)
Tel:847-709-0530
Fax:847-290-1451
www.amsperformance.com
Rich@amsperformance.com
Thank you
Rich K.
Marketing Director
Tel:847-709-0530
Fax:847-290-1451
