aftermarket wga w/meth?
Old Jul 1, 2007 | 01:41 PM
BigBallin's Avatar
i am goin to go with meth/water injection and am wondering if it is a no brainer to just go with the forge wga to help things out. and can i just bolt the wga up and run it until i can make it out to ams to get a tune
thanks kevin
Old Jul 1, 2007 | 03:01 PM
colo_evo's Avatar
i wouldn't boost any higer than stock without a tune. or at least a wideband
Old Jul 1, 2007 | 03:41 PM
BigBallin's Avatar
it would be safe to say i can install the forge wga and run the 20 psi. from what i have read the forge wga is to help the taper and it also will only let the minimum psi to be around 17
Old Jul 3, 2007 | 04:13 AM
Luis@TTP's Avatar
Forge WGA have three different springs that go for man different applications for meth cars we have the red spring installed 23-25 psi. the red spring will only tapper to around 24psi wih the proper pre-load on it at
7000 rpms.
Old Jul 3, 2007 | 01:07 PM
BigBallin's Avatar
7000 rpms.
thanks, so what boost do most cars that you tune run with the meth/water injection.
Old Jul 4, 2007 | 06:16 AM
Luis@TTP's Avatar
depends on customers setup but usually its anywhere inbetween 27 to 32 psi
Old Jul 9, 2007 | 06:33 AM
scheides's Avatar
EvoM Moderator
7000 rpms.
Really? This is opposite of all I've read. What is the proper pre-load for this spring? I may be calling you soon...
