Ok my little reveiw of the S1 for a IX
Ok I installed the S1 a while ago. I finally got to a dyno to see before and afters
. First I will start out saying when these were first installed. I turned the boost down to about 19 psi with a base map to start tuning. At 19 psi with cams I made more 2 byte load than 25 psi without cams. The car feels like a completely different car now. The car just pulls and pulls. I was not to concerned with peak numbers but I did pick up 35 whp peak.
The midrange difference feels incredible and my dyno sheets just confirms this. Anyone looking for cams for stock turbo anything under a 35r the S1 are for you.
The car was dynoed at the same dyno. No mods have changed, boost slightly higher by about a .5 psi, and weather was about 10 degrees warmer than my previous dyno. Let me know what you guys think. A friend did a little overlay for me.
Mods are, tbe, intake, licp, uicp, fp, ebc, and cams, 93 octane. Stock turbo, stck ecu
AFRs were dead on 11.5 till redline. A huge thanks goes out to John Bradley.
Hey kreionic,
Those are some really impressive numbers, the S1's really wake up the mid-range...your stock numbers (without cams) were also good considering you were not dyno tune! Did you log on the dyno with Evoscan?
I dont have a video of the idle. Like I said above the idle is very stock like unless you want them to lope. If you want lope adjust the mivec tables. I believe the lope on the 8 are pretty intense but I am not 100% on that
