clutch install, now steering problems
Old Jul 12, 2007 | 07:05 PM
PTevo's Avatar
Recent clutch install (by a freind who is a transmission specialist) and now steering wheel feels loose (compared to normal evo feel), and seems it seems to require more turning of the steering wheel to turn corners etc. He states that he removed the subframe to get the job done. Should I take it to mitsu?
thanks for any input
Old Jul 12, 2007 | 07:32 PM
cfdfireman1's Avatar
If the sub frame was removed an alignment is needed no way around it.
Old Jul 12, 2007 | 08:51 PM
KevinD's Avatar
if he took the subframe off, you very likely could have one of the sterring links loose or not connected correctly. check the one under the dash first. there is a double compression clamp thing over it.
