Need help......weird loss of power after parts install
Just install exedy clutch,act flywheel,megan manifold,o2 housing and buschur TBE
on my evo ix 5 day ago,while breaking in my new clutch i rev my car pass 3500 rpm for the first time i dont fell my turbo kicks in and try again coulpe times still i dont feel any torque from my evo ix its like im driving a non turbo car...What could be the problem?Any idea would be appreciated ... thanx
Did you do the installs? If you did them, are you experienced and all?
You could have a massive exhaust leak from the 02 or your clutch could be slipping badly. Do you hear any new noises? Is it possible you damaged the turbo somehow doing the 02 housing? More info is needed.
more info is needed. If you are not getting on the car there is not enough air moving thru the turbo to spool. How many miles are on the clutch. Dont miss with it until after the break in.
Thanks for your reply guys i decided to take out the manifold ealier and found the problem, blown manifold gasket came from megan racing so i just put back my stock manifold and its normal now....thanx
