Saikou Mitchi can quick question
Old Jul 14, 2007 | 12:29 PM
2StepsAhead's Avatar
I just installed it last weekend, and the past two days I saw oil spots in my driveway...figured it was a loose filter since I did the oil change at the same time but the pcv side of the catch can drain is whats leaking. I closed both drains, the intake side is clean but the pcv side is dripping very slowly, did I do something wrong and is it normal to have that much oil coming out of it already? I'm guessing I somehow didn't get the drain tight enough? But theres a spot the size of a half dollar, seems like a lot of oil for just a weeks worth of the catch can.
Old Jul 14, 2007 | 12:38 PM
EvoDan2004's Avatar
i have a catch can on my pcv side as well. it fills up fast...... faster then i expected......
i also have a catch can on the other side frunt right of the valve cover. for some reason that does not catch much oil at all.
Old Jul 14, 2007 | 04:25 PM
Got under the car this afternoon to make sure it was tight, noticed theres a sheen all over the bottom of the can...doesn't look like its dropping down from the top. Anyway that maybe the thread for the brass drain is somehow seeping?
