Evo Ix Mr Cams ? Every Opinion Counts.
Old Jul 19, 2007 | 04:53 PM
YzBrad99's Avatar
Ok i have a 2006 Evo IX MR and im going to change the stock cams. I heard the GSC S1 cams are great for mid end power without changing the valvetrain. And i do not want to change any valvetrain components. But im more looking for top end power from 5000-7000 rpms increase. What cams do you recommend for wicked power increases in 5000-7000rpms ??? i'm using it for drag racing only. and do you think i need to change the cam gears, is it nessessary ? or change the timing belt at 9000 miles when i have it tore apart ? im just trying to see if i can find cams that have more increase from 5-7k over the GSC s1's !!!! dont be a jerk, positive comments only please !
Old Jul 19, 2007 | 04:57 PM
Ev0luti0n's Avatar
From what i've heard from members, the GSC cams are good and yes you should change out your cam gears, fidanza is good for aftermarket cams.
I also saw a thread from a local and heard imput from a local tuner (TTP-Engineering) that teh Cosworth cams work as well also...
but it all depends on what size you're going. 272's? 280s?
Old Jul 19, 2007 | 05:23 PM
SHhhhh's Avatar
Cosworth. Awesome top-end, great mid-range as well.
Old Jul 19, 2007 | 05:26 PM
Tarmacisback69's Avatar
my buddy did the greddy evo 9 cams, he put down 408whp with meth, and sum crazy *** torque number, no valve train changes or anything
i understand the hks evo 9 cams just came out, but i wouldnt wanna be one of the testers for that cam
Old Jul 19, 2007 | 05:44 PM
LilRico's Avatar
I'm in the same boat... I'm between Cosi's and GSC
Old Jul 19, 2007 | 05:51 PM
msukach's Avatar
Having cosworths (and an O2 housing) installed and dyno'ed tomorrow...if you like, I'll post results.
Old Jul 19, 2007 | 05:56 PM
topturtle's Avatar
I installed GSC S1 cams this last weekend. Very easy to do. I used the stock cam gears. If you use aftermarket gears you will only need one as you will have to use the mivec gear. I hope to dyno this weekend. KevinD tuned it after install and there is very good pull on the car now.
Old Jul 19, 2007 | 06:05 PM
LilRico's Avatar
Please do!
Old Jul 19, 2007 | 06:51 PM
Chris@nolimitmotors's Avatar
Go with the cosowrth, you will be happy.
Old Jul 19, 2007 | 07:07 PM
1NastyMR's Avatar
Im going to be changing my cams to the GSC SC1 aswell and the guy from AMS told me that changing out cam gears is pointless in a way unless you got a build motor or a larger turbo were the timing comes into play but on stock turbo not needed unless you wanna spend the money.
Old Jul 19, 2007 | 07:24 PM
Luis@TTP's Avatar
+1 for cosworth cams ttp has evo 9 cams instock and gsc s1 evo 9 cams instock
Old Jul 19, 2007 | 08:39 PM
EVIL_EVO_VIII's Avatar
I went with Cosworths and love them!
Old Jul 19, 2007 | 09:07 PM
shbomb8188's Avatar
Get the new HKS cams, and tell us how they are.
Old Jul 19, 2007 | 09:11 PM
Noize's Avatar
EvoM Administrator
If I were doing it, I would want HKS cams, but these IXs make great power on the stock hollow bumpsticks, so I'm keeping them. I changed cams on my VIII and do not miss aftermarket cams at all.
Old Jul 20, 2007 | 01:55 AM
EvOcHaRgeR's Avatar
Like alot of people are saying go with cosi! They make good power on stock turbo and even more with a bigger turbo.
