Help with my new Engine!(clank noise)
Old Jul 20, 2007 | 04:40 PM
evovin's Avatar
So we are about to get done with my new motor...We put oil, coolant etc...
We unplug the conectors in the coil pack and start it to build oil pressure.....then we conect everything together.
We start it and as soon as it crank for the first 3 seconds....We HEARD A CLANK NOISE!!!...we thought it was the radiator fan hitting something... But it's not! Now My mechanic is taking off the oil pan and checking the bottom. Would this be the oil pump??? or something?? But the noise is similar when i broke the rod!(i hope not)
What else should we check?
Old Jul 20, 2007 | 04:42 PM
SilverEvo8owner's Avatar
no way a starter is gonna break a rod
will it crank?
Old Jul 20, 2007 | 04:51 PM
evovin's Avatar
it did crank!... it didn't die till we turn it off the engine coz of the CLANK NOISE scared us!....we only did it for 3 times. the third time we stop!
Old Jul 20, 2007 | 05:20 PM
Steve@NoLimitmotors's Avatar
if its an evo 9, the intake cam is gonna clank around until it gains oil pressure
Old Jul 20, 2007 | 05:22 PM
evovin's Avatar
its an EVO 8. But this is also the first time i put my hks 280's! do you think its the cams? can somebody verify this?
Old Jul 20, 2007 | 07:00 PM
evovin's Avatar
anymore idea what could it be? but how come when we are trying to start it with the coil pack unpluged...it didn't make any weird noise? it only made a noise when we connected everything and start it!
Old Jul 20, 2007 | 07:08 PM
PVD04's Avatar
You shouldn't try to spin it with just the coil pack unplugged. You are still dumping fuel into the cylinders. You should disconnect the crank angle sensor which will stop both fuel and spark. Not sure what the noise might be.
-Paul
Old Jul 20, 2007 | 07:16 PM
56Hotrod's Avatar
I'd triple check the timing.
Old Jul 20, 2007 | 07:43 PM
evovin's Avatar
if my timing was off....what could I possibly break?
Old Jul 20, 2007 | 08:08 PM
Lucas English's Avatar
Clank than the motor stops ?
Try and spin it buy hand to see if you feel our here it.
Is the motor still a 2.0?
Old Jul 20, 2007 | 08:09 PM
56Hotrod's Avatar
Valve hitting piston - bending valve, breaking valve, loosing compression...worst case, break or bend valve and lock piston bending or breaking rod - which may put a hole in your case.
Old Jul 20, 2007 | 10:45 PM
EVIL_EVO_VIII's Avatar
Take the head off and try to spin it by hand
Old Jul 21, 2007 | 12:45 PM
evovin's Avatar
we'll try that...
Old Jul 22, 2007 | 08:13 AM
evovin's Avatar
how about the flywheel? will this cause also the noise too when we started it?
Old Jul 23, 2007 | 04:17 PM
evovin's Avatar
timing went off!!! bend some valves and damaged pistons and rods...
Im getting a new pistons and rods now! Please suggest the best combo (piston+rods) Should I get Wiseco pistons and Manley rods or Oliver rods or Eagle rods or Crowers?
Basically I am decided of getting the Wiseco Piston but I haven't decided which Rods?Also which rod bearings??
