Cylinder pics....
Old Jul 21, 2007 | 03:23 PM
SiCKlEyWiKeD's Avatar
Cylinder pics....
Does this look bad? Anyone have comparo pics?
Attached Thumbnails Cylinder pics....-dsc02127.jpg   Cylinder pics....-dsc02128.jpg
Old Jul 21, 2007 | 03:37 PM
btw the specs of grit you see are from honing the other cylinders and not some kind of wierd pits.
Old Jul 21, 2007 | 05:28 PM
homemade wrx's Avatar
ok...so your skirts look like crap now...either that or the barrel section of your piston does, as it didn't quite have the right clearance for thermal expansion
pics of pistons..?
Old Jul 24, 2007 | 04:22 PM
SeanC's Avatar
pics of pistons..?
+1, Please post pictures of the pistons and rings (including the oil support rail if one was used). Look on the end of your piston ring ends for signs of them making contact with each other. Make sure the ring grooves have no strange scratches, or pits as well.
Old Jul 24, 2007 | 04:37 PM
I'll post pics of the pistons and rings when I get home but bascially they got pretty hot. On one of the cylinders ,before I honed it out, the rings actually got really hot and got stuck and rubbed the wall pretty good
Old Aug 5, 2007 | 01:44 AM
DAve4g64Mitsu's Avatar
yea we can see that big line mark on ur cylinder wall Aiya
Old Aug 5, 2007 | 01:50 AM
Old Aug 5, 2007 | 07:55 AM
Planet Evo's Avatar
Did you over heat ?
Old Sep 3, 2007 | 12:10 PM
EvoKnievo's Avatar
doesnt look ideal
Old Sep 28, 2007 | 11:03 AM
spikek1's Avatar
pics of your pistons would help seeing as how several things could be causing this. soo post em up!
Old Sep 28, 2007 | 12:29 PM
PVD04's Avatar
It looks like the most prominent scoring aligns with the ends of the piston pins. I would expect more side loading perpendicular to the pin.
-Paul
Old Sep 28, 2007 | 12:58 PM
SLVROZ_03's Avatar
Who gapped those rings and at what clearence?
Old Oct 14, 2007 | 10:58 PM
NewEvolutionIX's Avatar
The honing looks good but looks bad where the rings dragged
Old Oct 14, 2007 | 11:11 PM
Aby@MIL.SPEC's Avatar
it looks like the piston was biting the cylinder wall, well above where the top ring reaches.
are there any other cylinders with similar wear issues?
did you over heat or detonate pretty hard due to bad gas?
on durabuility engines, it was fairly common to see pistons experience erosion prallel to teh piston pin / on both ends of the piston pin & on the intake squish side of the piston too.
look @ the ends of the rings to see if they butted up to each other, if so, there will be a shiny spot on each end if it happened.....
Old Oct 15, 2007 | 11:06 AM
I was going to ask how you could tell which section but then looked at how high in the cylinder the scarring went...good call
