Extreme Turbo Systems - Intake System + IC Piping Installed Pictures
Old Jul 26, 2007 | 09:32 AM
ETS Michael's Avatar
We've had quite a few requests for these pictures so I wanted to post them up for all to see. This is our EVO intake system coupled with our short route UICP and included recirc kit. It looks so clean, I had to share
Tom
Old Jul 26, 2007 | 09:58 AM
Charlie_B's Avatar
Looks sick. Its on the list...
Old Jul 26, 2007 | 09:59 AM
SickSilverNLow's Avatar
looks absolutely awesome Tom.....
ETS FTW .
Old Jul 26, 2007 | 10:18 AM
V.8MR's Avatar
How much shorter than stock?
Old Jul 26, 2007 | 10:29 AM
crcain's Avatar
Internal diameter of IC piping?
Internal diameter of the ports on your intercoolers?
Old Jul 26, 2007 | 04:50 PM
evovin's Avatar
this is the shortest uicp I've seen!!! good job ETS!
Old Jul 26, 2007 | 05:41 PM
letMeIn's Avatar
damn looks real nice. I will put my order by the end of this year for the whole setup. Time to start saving $$$ lolz
Old Jul 26, 2007 | 10:07 PM
PWevo's Avatar
That's a thing of beauty, can't wait.
Old Jul 26, 2007 | 10:59 PM
ONRAILS's Avatar
whats this kit run and why use a type s? i thought they leaked under higher boost
Old Jul 26, 2007 | 11:45 PM
ec2k1gt's Avatar
realy nice pieces...
Old Jul 27, 2007 | 08:59 AM
oofastlineoo69's Avatar
looks good as always.
Old Jul 27, 2007 | 10:53 AM
The stock UICP is 60". Our stock battery UICP is 52" and our ultra short route UICP is 46" in length. The stock battery UICP pictured is obviously just tacked and not finish welded or coated. Here's a picture to illustrate:
Couplers are measured in ID while piping is measured in OD so that they play well together when matching up the numbers. Our standard intercooler piping for the EVO is 2.5" OD and .065" wall thickness but is available in 3" for those on huge setups.
The intake is $199 in stock MAF configuration or $189 in no MAF by itself. The UICP is $259 alone for the ultra short route version pictured. Of course these are available at additional savings in complete intercooler kits or packages.
The Type S works very well under 25psi and on the car pictured, pump gas and no more than 24psi was the goal. The Type S happened to be his BOV preference
Tom
Old Aug 11, 2007 | 06:01 PM
BigBallin's Avatar
for some reason my piping doesnt sit like that. my maf is rubbing on my uicp and scratched it all up. and once you get that uicp on it real doesnt have much room for adjustment. it only fits one way
Old Aug 11, 2007 | 06:09 PM
nick_622's Avatar
I had the same problem at first ... I ended up loosening all of the T-bolts on the Intake Kit, and pulling it out and up and then re-tightening all the bolts back down. My issue was that I had everything pushed in too far towards the turbo, and it really became evident when I bought their Recirc Pipe and realized it was about 1.5" too short. I had to re-adjust everything and now it fits like a champ. I highly recommend you pick up the Recircp Pipe, as it really helps to line everything up!!
Old Aug 11, 2007 | 06:11 PM
bigric09's Avatar
do you guys sell the recirc kit seperate ? id like one for my setup
