BOV flutter
Old Aug 1, 2007 | 10:35 AM
bubbagasm's Avatar
BOV flutter
I recently changed my BOV to recirculate and now I am getting really bad flutter. Any ideas what this is? I am a newbie to the evo scene, and never had a turbo car. Any help is appreciated.
Old Aug 1, 2007 | 10:37 AM
APEX1's Avatar
is it an ajustable BOV? what Brand is it?
Old Aug 1, 2007 | 10:40 AM
bubbagasm's Avatar
it is a turboxs BOV and it has the screw at the top. I tightened it snug but not tight...
Old Aug 1, 2007 | 10:43 AM
TeStUdO's Avatar
Your BOV has a really stiff spring, hence the flutter. You can un tighten the spring to get less flutter.
Old Aug 1, 2007 | 10:47 AM
APEX1's Avatar
To fix this, you need to adjust your BOV. Most BOVs have a screw or nut to adjust the
tension. You can turn the screw/nut to the right and increase the tension. Do this several
times with a test drive in between. If your BOV stops letting out the pressure, you have
adjusted it too tight. You will then need to start adjusting soft again. You must keep
playing with this adjustment until you get it just right. A good adjustment will allow the
BOV to release pressure after slight boost, and not stall afterwards. It is not necessary for
the BOV to release pressure when you rev the car.
good luck
Old Aug 1, 2007 | 11:00 AM
bubbagasm's Avatar
damn I just posted this like 5 minutes ago and already got a load of responses. I think I love you guys....not in a gay way or anything, not that there is anything wrong with that....
Old Aug 1, 2007 | 11:05 AM
jamerin's Avatar
I love this forum too... its been very helpful since i've join....
Old Aug 1, 2007 | 11:08 AM
joon82's Avatar
my stock bov flutters at low rpm =/ but holds boost well and sounds great in high rpm. Sux to drive around block making turkey sound
Old Aug 1, 2007 | 11:17 AM
APEX1's Avatar
Evom has the most traffic of ANY car fourm on the net. By far!!! if you spend some time on here you will learn alot about forced induction.
