stock battery install?
Old Aug 2, 2007 | 09:43 AM
boostin@27's Avatar
i need to install a stock evo battery back on my 03 evo 8. i have been running with the ams mini battery. so i just wanted to know the easiest way to uninstall the ams mini battery and then install the new stock battery with the stock tray? is it dificult and how much time do you expect it to take? just a nice write up step by step would be great.
thanks alot
Old Aug 2, 2007 | 11:58 AM
Luis@TTP's Avatar
thanks alot
its actually pretty simple the stock battery tray uses 4 12mm bolts and one 10mm bolt that holds the possitive cable. as to remove the ams battery its two 12 mm bolt most of the time why are you getting rid of the mini battery kit
