ACD fluid
Old Aug 3, 2007 | 05:28 PM
vikevo9's Avatar
ACD fluid
I have an evo 9 and just finished changing the cluth. The problem is that spilled the ACD fluid and don't know where to buy or what fluid should I use. I've been to many parts stores (even MOPAR (MOPAR is apart store dedicated to Dodge...and Mitsubishi) the guy here said he does not know what was the ACD). The cap of the reservoir specify ATF SPIII. Is this Automatic Transmission Fluid Dextron III? The owners manual specifies ACD fluid or equivalent.
HELP
Last edited by vikevo9; Aug 3, 2007 at 05:59 PM. Reason: MOPAR is apart store dedicated to Dodge...and Mitsubishi
Old Aug 3, 2007 | 10:24 PM
Luis@TTP's Avatar
yes you can use mitsubishi automatic transmission fluid in the acd
p.s. we just got back from puerto rico i miss it already lol
Old Aug 4, 2007 | 05:57 PM
vikevo9's Avatar
I'm glad you like Puerto Rico...
So I should assume that the mitsubishi sp III is not the same as decron III and It should't be used in the ACD
Old Aug 4, 2007 | 10:06 PM
Luis@TTP's Avatar
i have used it in mine seems to work but i wouldnt recommend it to my customers i rather test things on my car sometimes befor i tell a customer to do so i would go oem might save the seals in the acd pump.
Old Aug 5, 2007 | 05:21 PM
vikevo9's Avatar
Thanks for the advise. Let's see if I can find that oil.
