*NEW* ETS 57 trim turbo kit
Old Aug 14, 2007 | 10:38 AM
  #61
boostinpsi's Avatar
according to a PM convo ETS Tom and I had. The 50 trim is the closest to the 3076 whereas the 58 Trim is closer to Buschurs 3065.
Old Aug 14, 2007 | 11:38 AM
  #62
SickSilverNLow's Avatar
great info....
Old Aug 14, 2007 | 07:43 PM
  #63
uglyevo's Avatar
well looks like my plans for the dyno are over since my clutch has left the building. Today while doing a 2-3 pull on the freeway it decided to give me problems. However after letting it sit for a bit it seems fine now, but I think only until I rip on it a few more times and when its hot its toast.
so I am sorry to say no real data from me till next year
Old Aug 14, 2007 | 07:47 PM
  #64
Paul Nelson's Avatar
Old Aug 14, 2007 | 08:17 PM
  #65
Duby's Avatar
waiting for tom to Pm when my 58 trim is near complete and if I have the funds . . . SMIM too. dyno #s very soon after that so hopefully early to mid september. time to get kicked of the track weeeeeeeeeeee
if you can't tell i'm really excited. Kinda feel like a little kid at christmas!!
Old Aug 14, 2007 | 08:20 PM
  #66
Duby's Avatar
Just thought about it . . . I'll be running the stock maf w/ stock ecu on a stock block errrrrr TOM!! what kind of power do you think I'll put down? I'm nervous as too how long my car will last with 87,000 miles no t-belt job done either_ if it blows 2.1 or 2.3 over the winter
Old Aug 14, 2007 | 08:46 PM
  #67
uglyevo's Avatar
Depending on pump or race gas power should be from 420-520+. only one way to find out how long it lasts though
Old Aug 14, 2007 | 09:23 PM
  #68
That suck bro . Atleast next year you will have cams and maybe more mods .
Thats the way i felt when i orders my kit and about every supporting mods to go with the turbo.....my car was completely stock before this, so i was extremely excited .
I will be running mine with stock MAF and stock ECU and stock block too. I only have about 17k on my car though with no heavy driving. You should put down great #. I will have my numbers soon, so.......keep your eye out . So you went with a 58mm option??
Old Aug 14, 2007 | 10:59 PM
  #69
Duby's Avatar
Yea I plan on getting the block built, maybe the whole thing, plus some other goodies down the road.
Old Aug 15, 2007 | 09:28 AM
  #70
^sounds great...2.0l built or stroker??
Old Aug 15, 2007 | 10:18 PM
  #71
Duby's Avatar
ams has that new 2.3 that revs out to 9500 I thought so I'd be thinking of going that route
Old Aug 15, 2007 | 11:03 PM
  #72
TKMotorsports's Avatar
Originally Posted by Ted B
I just found a compressor map for each:
50trim
57 trim
The 57 trim appears to be less efficient than the 50 trim, especially at higher flow rates and pressure ratios. Using these two maps as a basis for comparison, the 50 trim is the better turbo.
You sir are correct. The 50 trim is more efficient than the 57 trim. Both turbos will make 400-500whp depending on fuel and boost, but the 50 trim does have a better powerband.
Here guys read the basics of turbocharger!
Q: What is a CHRA?
A: The CHRA is the center housing and rotating assembly, it houses the compressor wheel, turbine wheel, turbine shaft, bearing system and other small parts.
Q: So my compressor housing says .60 on it, does that mean i have a 60trim?
A: No, thats not true, the .60ar refers to the aspect ratio, but most know it as the size of the compressor HOUSING not the compressor wheel. you can put a 50trim, 57trim, 60trim, 60-1 and a wide range of others in a .60ar compressor housing. Just because your compressor housing says .60 doesnt mean that its a 60trim.
Q: What are the most common T4E compressor wheels?
A:
-40trim (T4E compressor wheel)
-46trim (T4E compressor wheel)
-50trim (T4E compressor wheel and a SRT favorite)
-54trim (T4E compressor wheel)
-57trim (T4E compressor wheel one of my favorites)
-60trim (T4E compressor wheel)
-60-1
Q: What are the most common compressor housings?
A:
-50ar
-60ar (T4E usually has a 3" inlet)
-70ar (T4S usually has a 4" inlet)
Q: What does T3/T4E really mean?
A: Well a T3/T4 is a hybrid of a T3 hot side and a T4 cold side. The T4E refers to a family of T4E compressor wheels that is paired with the T3 thot side (turbine side).
Q: What turbine housings are available on a T3/T4E?
A: Well there are 5 basic turbine housings, available, they are:
.36ar (very uncommon and usually too small)
.48ar
.63ar
.82ar
1.06ar
Q: What does stage 3 mean?
A: Well stage 3 is a turbonetics term for a specific turbine wheel, Garrett has a term for basically the same turbine wheel, but they call it "T31"
There are 3 basic turbonetics turbine wheels: Stage 1, 2, 3, and 5
The higher the stage wheel, the slower the turbo usually spools, for example, if you have a 50trim compressor wheel, the stage 1 turbine wheel will spool faster than the the stage 5 turbine wheel, but it will not flow as much turbine gases as a stage 5 at high RPMs.
Garrett turbos use different terminology, the stage 3 is referred to a T31 with a 76trim, the stage 5 is referred to a T350, most guys use stage 3's or T31 turbine wheels.
Q: A 60-1 says it has the same trim as a 60trim, whats the deal with that?
A: Well they do have the same trim, but the 60-1 has an additional compressor blade (7 compressor blades) instead of the standard 60trims (6 compressor blades)
Q: How do i calculate compressor wheel trim?
A: Trim is calculated by doing the following equation:
Inducer Squared, divided by Exducer Squared, then multiply the equation by 100.
IE:
If your inducer is 80mm then:
80^2 = 6400
If your exducer is 100mm then:
100^2 = 10000
6400/10000 = .64 x 100 = 64trim
If you guys have any tech questions feel free to ask
Tim
Old Aug 16, 2007 | 07:54 AM
  #73
evo_8_u's Avatar
^ very good info!!!!!
Old Aug 17, 2007 | 12:02 AM
  #74
Duby's Avatar
those compressor maps make me nervous, especially testing out the 58trim which no one has yet. running 30-32psi on pump meth . . . getting tuned early - mid september. Tom I hope this is some good stuff, If you get your 58 on and tuned, get back to me asap with some numbers, dyno chart and feedback
Old Aug 17, 2007 | 12:11 AM
  #75
boostinpsi's Avatar
yea if you wanna pay 8 grand for just the shortblock. sick motor but thats ridiculous.
