Shift Calculator
Old Aug 5, 2007 | 04:45 PM
oneguy's Avatar
Shift Calculator
Save the file and change the .txt extension to .xls to open it.
These excel files will output actual TQ at the wheels, not the torque your engine is making. From that you can determine at RPM you should be shifting.
The directions are inside the excel files. For this to be useful you need to have a dynograph of your car's WTQ.
The Shift points already in the files are ones that I did for another graph so you can use them help you understand the program if you need it. They are specific to the dyno data already in the file so yours will probably be different.
File Type: txt
File Type: txt
Old Aug 18, 2007 | 10:15 AM
lemmonhead's Avatar
link dont work for windows vista, just shows garbage?
Old Aug 18, 2007 | 01:51 PM
oneguy's Avatar
Did you change the extension to .xls?
Shoot me a PM with your e-mail address and I can e-mail the files directly to you but as long as you can read excel files it should work.
